Heya guys,
I'm converting a 25det neo from a Stagea to RWD so it can be used in a 33, using the sump from a S2 25det.
The NEO has 2 baffle plates attached to the main girdle, the rear plate needs to be removed to fit the 33 sump as this has baffles attached in the sump where as the awd sump was just a flat surface. I imagine this will be OK as the 33 sump looks to have a very similar baffle layout to that of the removed plate, or is it a better idea to remove the sump baffles so the neo baffle plate can still be used?
When removing the baffle plate the bolt holes on the main girdle are left empty, should the bolts go back in to maintain rigidity? Otherwise I'd probably leave them out to prevent the chances of one coming lose down the track.
Cheers!
post-63773-0-78265000-1437452780_thumb.jpg post-63773-0-77741600-1437452719_thumb.jpg
https://www.sau.com.au/forums/topic/458384-25neo-awd-to-rwd-baffle-question/
Pretty sure we removed those baffles on mine.
What are you going to do with the oil pickup?
TBH I hadn't looked at the pickup yet to realise it's different! Went to work on it tonight and saw the problem..
Baffles have been cut out of the 33 sump and the original plates put back on the girdle, this will hopefully fix both problems. Waiting for the sump to dry 100% after cleaning out the shavings from cutting and will test fit everything again.
  • 3 weeks later...
Just a bit of closure for if anyone searches this in the future.
An R33 sump will not fit the NEO block, even though the block was drilled to accept the 2wd 33 sump there is no way it will fit without some serious modification to the pickup, or to the sump (cutting and welding type modification). Fitting a 33 pickup does not solve the problem either.
I ended up getting a neo 2wd sump and bolting that on instead. To make it fit in an R33 the power steering lines need to be un bolted from the front cross member and held out of the way as the engine is lowered in, if you don't do this the fins on the neo sump will crush the lines. Once the engine is on the mounts you can clearly see how to re-route the powersteer lines around the fins.
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
