Hello all,
I don't see any PDF online of this service manual being in OCR, so I'm posting a link of one I made.
OCR makes it so much easier to find things, being able to search the document with Adobe Reader.
(old link removed).
new link - https://drive.google.com/file/d/0B495mmNsnU6uYzAwLV9fVW9WREk/view?resourcekey=0-Qa9Lfekqc5AnkoecCkM5xg
It's 489 pages long.
Edited by Duncan
OP request to correct link
  • Like 3
This is great.......clarity [OCR working wonders] is way better than the copy I have been using.
Thanks for that, your a legend.
GTofuS-T - time to scrub that sand off your tyres......lol
  • Like 1
  • 6 years later...
On 22/07/2015 at 11:13 AM, jamesnorman93 said:
Hello all,
https://drive.google.com/file/d/0B495mmNsnU6uYzAwLV9fVW9WREk/view?usp=docslist_api
Hmm... I can't seem to edit the original post/link... Please don't click on it! If a Moderator (@phantc_s15?) could update it, that'd be great! :thanks:
Google Drive have done an update and broke the old link. (Apologies to ones who've been trying to get this file the past couple of days!) 😅
Below is the latest link to the exact same file:
Nissan Skyline R33 Service Manual_OCR.pdf
I'll also attach the file below as another source of downloading it.
1148653_NissanSkylineR33ServiceManual_OCR.pdf
    • Do the R32s run high or low impedance injectors?
    • It may not feel like it to your wallet....but sounds like this was one of those "lucky you did it" rebuilds. Hopefully you have better luck this time
    • It's aftermarket. It also reeks of Honda Civic tryhard from 2003. But if you want one....then you want one.
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
