Hey my mechanic says he knows a bloke who can tune GTRs and Stageas without any piggy back.
He's cracked the factory ECU's and can access everything.
I haven't met him yet but it's pretty exciting, maybe won't have to drop 1K on a daughter board and install.
I wouldn't mind knowing how much more you can get out of the VQ25DET with factory afm, turbo and injectors.
Not interested in E85, considering going for the Hypergear G1.
Will post updates as I get along.
https://www.sau.com.au/forums/topic/458420-m35-tuning/
I bet he is talking about c34 stageas. As mentioning gtr and m35 in one sentence would make no sense as the ecus are not even slightly similar.
But great news if he has, but until i see it i am very very skeptical
Edited by Brick
  • Like 1
https://www.sau.com.au/forums/topic/458420-m35-tuning/#findComment-7571485
No, he started on the R35 and has also done M35.
Played around on the circuit boards and analysed how they work.
Curious to know what software he uses.
https://www.sau.com.au/forums/topic/458420-m35-tuning/#findComment-7571490
Next question is pm35 or nm35. PM can be hacked using uprev software.
Not trying to shut down what has been said. But we have heard this so many times before and nothing ever comes of it.
The issue with the nm35 is that the ecu is nothing like any other nissan ecu.
Hopefully he is right though and another tuning option might be available.
https://www.sau.com.au/forums/topic/458420-m35-tuning/#findComment-7571495
Where is your mechanic located?
If he's telling the truth, he's about to get quite busy.
https://www.sau.com.au/forums/topic/458420-m35-tuning/#findComment-7571497
Is it Toshi? He mentioned basic reprogramming a few years back if there was enough interest.
I have heard of many attempts to hack the stock ecu, but I am yet to see anyone locally unlock it, I can't even get a decent uncorrupted copy of the stock rom, with that theoretically a hex programmer could work out the maps and perhaps adjust certain aspects of the tune. I'm just not holding my breath for a decent solution any time soon, even if he has managed to communicate with the processor.
https://www.sau.com.au/forums/topic/458420-m35-tuning/#findComment-7571546
My bet would be "a guy" is Toshi.
We were discussing him bringing over the software from Japan that would allow rewriting of the stock ECU in much the same way as UpRev can for the PM35's.
Cost was far too prohibitive at the time though. so perhaps there is another option that has been presented... or he has the software now due to requests from some deep-pocketed R35 owners?
Even though I don't own the 2.5t, I would still very much like to see a remap option become available and the results of a "real" tune.
So much history, so much Stagea love :wub:
If you need a stock ECU, let me know as I have one in bubble wrap here.
Edited by iamhe77
  • Like 1
https://www.sau.com.au/forums/topic/458420-m35-tuning/#findComment-7571862
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
