Hi,
I'm currently in the process of doing some audio upgrades in my car - the next step looking at upgrading my front speakers. I've already pretty heavily sound-deadened the car - in the boot, rear seat area, parcel shelf, and front-doors.
The setup currently consists of a sunlight readable double-din touch-screen in the front, plugged into a car-pc running Centrafuse in the boot. Sound from the car-pc runs via an optical cable into an Audison Bitone, and from there into a pair of amplifiers. An Audison Voce Quattro is used for the fronts/rears, and a Kenwood KAC-9105D for the subwoofers. Rear speakers are Alpine SPR-60 - which should be adequate for the task (they're just rear fill, really). I have a pair of old - but capable - Kenwood KFC-W1204dB+ 12" dB+ for the subwoofers - I'm probably over-powering these.
The fronts are still some cheapie 3-way Pioneers I bought to upgrade the factory paper factory speakers when I bought the car in 2007 - with all of the other upgrades that I've performed in the meantime, they're really letting everything else down.
I've been heavily eyeing off the FOCAL K2 Power 165KR, but I'm not even sure if they'll fit in the front.
Does anyone have any experience with these speakers, and can share their experiences? Does anyone know if they'll even fit the front doors of a skyline (R34 GTT)?
Thanks in advance.
https://www.sau.com.au/forums/topic/458432-focal-k2-power-165kr/
They will fit in the front of a r33 (can't say for 34), but you need to do pretty heavy dremeling of the factory mounts to do so. Both the diameter and the mounting depth is larger (bigger speaker basket and larger magnet) so you need to be pretty savage. Still plenty of room to clear door trims and window mechanism though.
Re-purposing the factory mounts still seemed better then using mdf which will deteriorate as soon as it gets wet.
  • 3 weeks later...
Last night I removed the A-pillar covers, and factory tweeters to assess fitment. I'd been warned these were a fairly shallow location, and I might have issues mounting aftermarket tweeters here. I removed the grill and flush-mount cover, which reduced the size of the tweeter, but it was still a good 3-4mm thicker than the R34 factory-option tweeters. For test-fitment purposes, I attached the tweeter to the back of the A-pillar cover with some tape. The cover snapped into place, and seemed to have sufficient space for the tweeter, without any obvious rubbing. So it looks like this could be a win.
Plan now is to adapt the factory tweeter mounts to hold the new tweeter in the correct location. It's probably not the optimal location sound-wise, but it definitely achieves the factory-look that is important to me.
Then onto the main speakers in the doors, and finding the best location to mount the cross-overs.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
