<script async src="//player.cnevids.com/embedjs/5176e89e68f9daff42000013/video/55ad80d461646d4db7000005.js"></script>
Amazing oversight by Chrysler to allow hackers access to some pretty important functions of the car.
I'd hate to know what other manufacturers also suffer from these massive security flaws.
Full post here.
  • Like 2
A load of $hit IMO.
It took them 12 months to write the code to be able to do it but I would bet my left nut that they had to make some modifications to the vehicle to make all of that stuff happen. I don't believe most of the stuff they were controlling in the car would be possible without making modifications.
The full story will come out once people are sick of talking about it and the story needs reinvigorating.
However, it is very interesting to see the potential dangers of having fully 'connected' cars, houses, etc.
  • Like 2
A load of $hit IMO.
The one thing that had me scratching my head was the steering wheel turning, but I guess with 'assisted' reverse parking, there'd be servos in there.
It seems extreme to be able to control that much with code, I agree, but then I know so little about new cars and their capabilities through internet connections.
Next comes the police have power to disable and pull any car over ending the need for high speed chases?
The problem is the hackers working against the system are always better than those working for. The "smarter" cars become the easier this will be. But who knows.
Focused EMP, fry a cars electronics and it will stop.
This is possible. This is how exploits work. I am a software developer and what they explained is essentially an opening into the cars software via an outbound connection. If the vehicle can auto reverse park then they can control the steering and this may explain why they were only able to control steering in reverse.
This is very plausible. The same way a computer can be remotely hacked and controlled, if the electronics in the vehicle are linked via one ECU and you can open and close signals via an outside source then there is good basis to give this credibility. The first of anything connected to a network is very prone to being exploited. I remember when bluetooth became big, you had bluetooth viruses just by walking near someone with an infected mobile which could send you a virus if your phone was actively running bluetooth.
Nothing is impossible.
Edited by SargeRX8
  • Like 2
I'm also a software dev and have been casually following this for a few yrs... and I'm not surprised at all. Lots of juicy targets once you essentially turn a car into a mobile, internet-connected computer.
Any part of the car that receives data from the internet could have a security hole that would lead to system compromise, and from the sounds of it, everything in the car is connected via a CANbus network, where any subsystem can send commands to any other subsystem, so if you break into the entertainment system (via exploiting, say, a web browser), you can then directly access and disable brake-by-wire or whatever else.
From the sounds of it, the security researchers seem to have found a way to do it without user intervention, which is somewhat more disturbing. Makes me suspect that they've exploited an automatic software/firmware update process for the entertainment module. Which is not a trivial process to create but not really rocket science, esp not for a multi-billion $ car company
Edited by Skepticism
But hey it might mean the end of forking out for aftermarket ECU's if you can easily hack the stock one and tune it!
Also I'd like to think the aviation authorities have their shit together.
    • I've sent JaseR33 a private message in the hope he gets an email and contacts you
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
