I am probably going to be picking these up tomorrow. (Will be my only opportunity).
Due to the numbers I may only be able to grab a few of these and not all 8/9.
Also, if you guys want to grab the mats while I am on route then it will probably be pretty early in the morning lol. I would suspect me to hit Sydney from 3am ish.
Please voice any concerns asap.
Ok. So I picked up some mats. I ended up with 7
2 x Trident - Gtst Series 2
1 x me - R33 GTR
1 x kingtube - Gtst Series 2
1 x kil32 - R34 GTR
1 x RoB - R34 Gtt
1 x Aqua - R34 VSpec II
Scrmr for some reason yours is said to be the one on back order. Sorry but I did not pick yours up because we didn't want to risk confusion or conflict. So we stuck to the master list that import monster had.
  • Like 1
I can meet you anywhere around Sydney - Just let me know what time you plan on being in Sydney and I'll be there doesn't matter what time of the day/night as long as I know a few hours beforehand please
Thanks again for picking them up!
@kila32 Hurstville is quite a deviation to my trip. As you can see I do not literally go through Sydney. If I start to deviate for each person my already long trip will turn into an even longer one.
Guys, I am doing this free of charge. Even import monster said I should be getting beers at least :P.
Like I said from the start, meet me on route
Or come pick them up from mine.
If that does not suite you then I will arrange postage for your item at your expense.
But I would say it's safer for the mats to transfer through less hands. Otherwise it might turn into a he did this or that situation.
So far kingtube is on my list for pickup in Sydney. If anyone else wants to pick there's up then I will arrange a time and location for this mass exodus to take place.
Be warned it might be late/early and probably Sunday.
Hey bud constitution hill, near Wentworthville and seven hills. Wouldn't make you go all the way to Hurstville. Anytime will be fine mate. If you give me a location i'll come there.
Kila32 can pick mine up and I'll grab it from his place cos he's such an awesome mate :P
Same here if Kila32 and Hadouken don't mind, please drop mine off at Kila32 too, I will pick it up there.
Thanks in advance!
  • Like 1
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
