Looking into getting a kando turbo and recall int he past the internal gates where prone to spiking.
I have heard recently that the issue has been resolved. is this true?
or am i better off spending the extra on an external gate setup
Unless they enlarged the wastegate puck and opened up the hole I would stay well away, stick to the products you know won't boost spike, such as Hypergear or Garrett, or going external gate is the best option imo if you can keep it looking stockish. There are some great gains to be had if an external setup is done right.
yeah currently making just over 210kw but was looking at stepping up to a bigger turbo/more power but with similar response.
i had heard the hypergear high flows where laggier than the TD05 18g kandos?
Hypergear do a wide range of turbos with varying flow, some like the SS2 are very responsive for their power capabilities, and run a more modern CNC compressor, much more efficient than an old TD cast compressor. This will add to the cost of course, but I am sure he could make a cast version for similar pricing to the Kando with the same wheels.
Garrett do some nice GTX28 series turbos that would be perfect on an RB20, but you are looking at twice the cost of the kando.
I would contact Tao and speak to him regarding your goals, you have nothing to lose, and it's not something you want to jump into without researching all your options.
definitely worth finding all the options and pricing before i spent the money!
i am getting a leak down test done in the next week to check on the engine health before i even think about buying something :unsure:
Good idea, if it's no good a stock RB25det Neo would get the power you are chasing with no lag at all. :P
yeah det neo would be the path id take if my RB20DE+T dies. but i love the 20's hahah
Another option is to run e85 on the turbo you have now, more power potential just by filling at a different pump, as long as you have the injector overhead. Obviously best if you have a servo nearby that sell it.
I have ported the shit out of my kinugawa td05-18g wastegate hole, it helps but still does creep up to 17+ psi around 5500rpm, on an unopened rb25 with usual basic mods. Although, it seems the turbo works best over 1 bar anyway. Electronic boost controller is used just to bring it on boost, and with the 8cm housing it is defintely not laggy. Have one of the new hypergear hiflows on the way just cos, am keen to see the comparison between the 2.
Currents mods not really ideal for E85. injectors not big enough for E85 and turbo is the bottle neck as it is.
RB20DE+T
RB25 turbo (0p6/neo)
R32 GTR injectors
Ebay plenum
R32 GTR cams with solid lifters
profec b spec 2
etc
would be interesting see a comparison of the results of the two! be sure to let me know?
guessing you're not in Brisbane from your car pic there but if you are you're welcome to have a drive yourself to check it out before I swap 'em over.(td05 will be for sale cheap too :P, if you were considering one of them)
What turbine housing are you running? Any pics? There are a few different versions now...and the latest offering which is a Skyline specific T3 "looks" right compared to the avomination housings they use to offer as their internal gate, T3 offering.
If someone wants a new 18G cheap I have one laying around which is no good to me since my 20 overheated
Roy that 2nd one is the one i use, i have both the 10cm2 and 8cm housings. It is not a physically small turbo, turbine housing is much larger that stock, so i consider its response to be very good, it may not have any boost creep on a lower displacement rb20 with the wastegate ported out?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
