What a great day indeed!!! my first DECA is hopefully the start of more to come!!!
Big big thanks to the SAU Vic DECA crew - Bec, Ryan, Leon and Wayne (if there are more thank you too!)
Also thanks to all the people who helped on the day, things like this wouldn't be possible without people like you :P
And last but not at all least thank you to those who were competing, hope you had a blast and that we will see you all for the next one :)
  • Like 2
Had a great day out, tag teaming in the little red mx-5 with Jack. Just wanted to offer my thanks and appreciation for those who volunteered today. It's often a thankless task and without you guys it would not go ahead..so thanks a heap!
P.S whats the std timeframe for timing results?
Jarrard
  • Like 2
Anyhow here is my videos off the skidpan
Group1 is the first group on skidpan
Group1 is the 2nd group on skidpan surprise surprise
battle1 and battle2 the 2 sessions in the arvo.
usual rules apply
if you upload to social media eg youtube facebook so on please tag SAUVic and myself EMTS
(this is our advertising for the next one so if you want to keep them running....)
if you want to use for any commercial purpose please contact myself.
  • Like 1
Another great weekend. I'm sure everyone involved in reviving deca would agree it was worth it! Always good to catch up with everyone, was also great to meet a bunch of new people.
Big thanks to all our volunteers on the day. Massive thanks to Wayne for organising all our helpers and spending the whole day out on the skid pan.
Great work Odi with the online entry system. It has certainly made entering a whole lot easier!
While its unfortunate your car broke Martin, its great to have footage from the day! Looking forward to seeing some photos from the camera guys getting around.
There are a lot of people who have helped out with deca and make it the fun event it is. Your help is appreciated.
See you all at the next one.
https://youtu.be/Xrw36bSZni8
  • Like 2
Also should have some cool drone footage from Tony on the way :)
Thanks Martin for the camera work.
And a massive thanks to Bec, Ryan, Leonica and all the volunteers for organising and running the day! Had a blast as always.
Note to self: avoid midgets at the pub, it doesn't end well
  • Like 1
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
