Stagea Big Wheels
I know wheels have been covered before but I wanna know what the lowest offset 19" wheel someone is running on their M35 or PM35 stag. I'm looking at a 19x11 +10 rear and 19x10 +23 front, I know the fronts will fit but unsure of the rears? The car is on air and I know ill have to run a fair amount of camber.
Camber is not a solution for wheels that don't fit. The wrong camber will upset your handling and chew out tyres. Modifying the guards is the way to go. Or getting wheels that fit.
BTW the smallest tyres you should run on 11in rims is 275 - better is 285 or 295 (max 305)
  • Like 1
The stance life is obviously not your life. I understand alot of camber will wear my tires faster but I'm wanting to know what the lowest offset someone is running on their car. I need to clear big brakes and want a lot of dish.
Yeah you aren't going to make too many friends on here or (by the looks of it) get any decent responses.
http://www.sau.com.au/forums/topic/92233-stagea-wheel-dimensions/page-34?hl=%2Bm35+%2Bwheels#entry7295817
search function helps too but i'm not sure you will find much info on what looks good stance life wise
Good lock
Stance life is not the popular life on here that's for sure.
So yu have big brakes for looks also?
I understand alot of people hate stanced cars, im not one of those blokes running double digit camber and scrapping on leafs. The big brakes are an upgrade over the stock shitty ones, I thought I may as well go big. 356mm fronts and 330mm rears
  • Like 1
Yep I'm one of those who prefers function to stance but hey its your car - go for it. But I doubt you'll fit 19 x 11 with 10P without modifying the guards and perhaps not even then if its fouling on the inside..
Try this site:
http://www.willtheyfit.com/index.php?width=215&aspect=45&diameter=17&wheelwidth=7&offset=45&width2=235&aspect2=40&diameter2=18&wheelwidth2=9&offset2=35#content
Try this site:
I've been on that site quite abit but it's hard without having the wheels to test it in person. The guards will definatelly have to be modified, time to test fit some wheels I guess.
Here's a start, more aggressive than the specs you've listed but something to throw in to an offset calculator to compare if nothing else.
http://www.stancenation.com/2013/01/06/stagea-from-across-the-pond/.[/quote
Perfect stagea, im buying very similar wheels. With everything online I'm not sure if people are using spacers, I don't want to.
There is never any need to use spacers if you can afford to buy the right offset. But note that the featured car has had megabucks spent on reshaping not just the guards but the doors
I understand that car is far from stock and no doubt it isnt using spacers, however there's alot of cars that do run them. I think I've found some offsets that I'll be able to work with though. 19x9.5 +10 and 19x 10.5 +15
This is my friend Oliver's PM35.
He has removed the Semi's in the above photo and fitted more sensible sized tyres to fit inside the guards.
R35 GTR Wheels with bolt on spacers at the front.
www.oliversimportheaven.com
  • Like 1
That M35 above is mine. Yes semi slicks are gone, replaced them with 245/35/20 on the 9.5 fronts and 275/30/20 on the 10.5 rears. Fronts have 25mm spacers to clear the brakes but still fit under the guard without a problem.
My rear tyres have around 3mm clearance to the plastic guard with camber around -1.5 (not sure haven't had an alignment lately). Non axis models don't have the plastic guards so may be different for you.
Depending on tyre size you could possible get a 19x11+10 to fit, but camber would be up a bit.
Also, just curious, which air setup did you get? And is your car RWD or AWD?
  • Like 1
 Share
    • This is a simple swap when you reuse the RB20 loom and auxiliaries. I run a standalone, but if I remember right, using the RB25 ecu you only have 2 injectors to inverse.  There are many DIY's on this subject online, including this forum.
    • Surprisingly the D6000 is only $1999, I'm waiting for the BF/CM sales, and hoping to get one cheaper. D4000 is well priced, still outperforms the 13" SVS PB-3000 and is like 1/2 the price at $1699 RRP. I do watch a fair amount of movies, and listen to EDM, jazz, symphonies, etc. so the lower notes from a subwoofer are always appreciated. The front 8" stage, just doesn't provide you with lively feeling, even though they are pretty bassy for a pair of large bookshelves. Then again, these days it's just playing Wiggles, Blippi and Ms Rachel, another reason the 3m wide cabinet exists, to hide all the audio gear behind it. They used to sit on a nice pair of stands, but as you know, they make good baby traps too.
    • Granted, which is a solid reason why I don't have one. My floorstanders are only -2 dB at 22 Hz.  So they're still working down to <20 Hz. Which is no doubt part of the reason why my receiver shits the bed! That Tonewinner would be about double the cost though, so it's not apples and apples. There aren't many AU$1300 subs (that you can buy prebuilt, I'm ignoring what can be achieved by DIYing) that compete.
    • -6dB at 22Hz isn't that great, watch the data from the D6000 from REW
    • I'll just leave this here. https://www.adelaidespeakers.com/subwoofers.html TL loading, big power. They sound awesome. This is what I would buy if I was going to try to take the bass away from my floorstanders. Just go with the 12".
