Good Day...R34 RB25det with power fc and Precision 5558 here running 98.
Had this problem for a while. Stopped at lights I need more throttle to take off normally or it will vibrate, half stalling or in the worst case jerk / lurch extremely violently, coughing/gasping. Push in clutch and /or apply bit more gas it will recover n drive normally. Cold starts are perfect, cold driving for first ten minutes are always smooth and car purrs like a cat with lotsa low down torque. Once warm it runs and sounds rough, loses some low end torque. Doesn't purr smoothly anymore. Only stalls /feels like stalling when taking off with not much throttle. Boosting is fine, no hesitation or misfires, revs clean all the way, goes MUCH harder on colder days. Oh and car idles/runs a bit rougher with O2 feedback off, so I always have it on. Car has 1 sec or sometimes 2 sec LAG from stop to go most times. Very annoying. Have to keep feathering throttle.
Tested n fixed couple vac leaks, changed fuel filter, found tiny leak on wastegate clamp where it sits on turbo housing. (Tiny soap& water bubbles in that area when idling). Coolant temp sensor seems to be working cos the commander displays change in temp from start first couple mins about 25C and then goes up n normally sits at 72C or up to 80C boosting hard for a cew mins on warmer days. Idle air control valve (IAC) has been removed n cleaned twice, m sick of it. Used a gasket paste though so not sure if leaking, spraying WD40 there and on joints/suspect areas doesnt change engine note though. TPS is 0.46V at idle and voltage changes with accelerator stabs so assume its fine. There could be more minor vac leaks though as this test was done sometime ago. But prob was there then even after fixing leaks. Havent fixed the tiny wastegate leak though, tightening v band n it still leaks slightly, holds boost well though.
Kinda lost here on what it could be.. Fuel pump is a walbro, directly wired. Air filters clean and Z32 is plugged in tight and joints re-soldered, sensor element cleaned.
Edited by rondofj
https://www.sau.com.au/forums/topic/458475-idle-and-initial-takeoff-probs/
Ben, remember when you guys once suggested to get the afrs checked, well had that done sometime ago at unigroup, was all good. TPS at idle is 0.46V and pedal to floor ( keyjust at ON) from memory is around 4.8V or something- will check
Whats the section of the map like that you're in when taking off? Might need a bit more fuel, which would not be as evident when aided by cold start enrichment, and if its only that small section of the map you wouldn't hit it when driving otherwise, only at takeoff.
Just tested -TPS idle is 0.46V and pedal to floor is 4.07V.
Coolant temp sensor at 18-20degs is around 1800+ ohms and dropping roughly an ohm a second as engines running/warming up. Was around 1490 ohms after say 5mins and showing 41degrees hot on commander
I have no idea about power fc's sorry, someone else would need to input there. I just had a similar issue on my other car which runs a Wolf 3d V4, low in rpm range under light throttle. Quick look at the fuel map showed it had a nasty hole lol, smoothed out that section and never looked back.
To me, their are fairly decent jumps in the ignition cells as it jumps up from N01 to N02 and then N03. From memory my N01 and N02 cells were set at a number down to about L04 or L05, 20 degrees I think is what I had there. The Power FC does its own thing with timing at idle (has its own idle map that you cannot access), but I think I found that playing with these cells made my idle a little bit nicer
It wouldnt hurt to try at this stage, just take photos of what you are changing (assuming that you dont have FC-edit and a Datalogit or FC-Hako) that way you can set it back to normal if it makes it worse
I'm no tuner, so I'm not giving you a 'this is definitely the problem' answer, hopefully it is a helpful suggestion anyway.
Fueling, its hard to say without a wideband, and I don't feel comfortable telling you to change your fueling without knowing what its at and where it is going. Shouldn't really make much of a difference at idle, but none the less
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
