I wasnt racing for this one , but saw a few nice skylines . Also I mean CALDER :Oops:
Franks white R33 GTR was absolutly flying and i think would have won the day easily posting in the 63 sec bracket .
AVO had a strong R33 gts t which sounded great and had plenty of straight line .
A black/purplish R33 GTR with black GTR rims was out but seemed to have ignition dramas later in the day .
Also a grey R33 gts t which seemed to have a constant misfire but toughed it out all day .
Its good to see these cars on the track and i know the rexie boys are always keen on watching their progress
adam
https://www.sau.com.au/forums/topic/45850-skylines-at-wrx-club-sandown-event/
There will be a few more joining the ranks i think Adam.
an 34GTR (once gearbox is done)
an R31GTS-R (once my motor is done)
a 32-t - im sure Roy (troy) will come with us
Maybe a 33-t , someone might have to twist Geoff arm?
probably a few more too :D Hope their keen attitude sticks around :)
....and some stickies :D
lol... who has a rubber fetish :) ...ignorance is bliss, just disconnect your oil temp gauge or be sure to get the cooler before the rubber :D
Yeh once the old battle hardened R32 has stopped its hissy fits and is back together running, ill be good for just about any track day that doesnt clash with work commitments.
FLYGTR you say an R33 GTR posted in the 63 second bracket, i take it Sandown has a short track?!?!?! as i think V8 Supercars do 71sec laps?!?!?!
oooo VIC track team now, i'm so heading out with you guys once my car is regoed. R34 GT-T, one of the reasons i bought it was so i could race it. Have the Mines R34 GTR to thank for that :D
Need to do anything to be part of Team Wang :)
Posted by Roy
The event was at Calder, I'm sure that's what he meant.
The purplish GTR is mine and had to retire after the first session.
Emre - heard you may have lost a piston. Any truth in the rumours?
FLYGTR - I'm going to join the rex club. Their track days look well orgainised. Do you go to the general meetings? I was thinking of going down this Thursday and checking it out. Apparently the Maserati Club is joining the MSCA next year so those track days could get very crowded.
I might have to defect to WRX club as well! :Oops:
Andrew,
All the possibilities went through my head on the day, but it's not internal.
The car has a very erratic idle and running on 5 cylinders in in low rpm, but i have no loss of power. I am leaning towards an AFM or a dud injector in no:3 cylinder but haven't found out for sure yet.
The day was organised very well. They had 75 cars entering the track day and there were plenty of laps to be had.
probably a few more too  :D  Hope their keen attitude sticks around  :D
dont forget the ceffy! :thumbsup:
Well Emre I hope it all turns out to be as painless as possible for you.
Had a look at the rest of the track days for the year with the rex club - their timing is shocking. Next one is the weekend after the dutton, the one after is on Grandfinal Day (I'll be there) and the final one is the day after Derby Day on the Nov Long weekend (BIG drinking day for me).
So that sucks.
Hey guys , i meant calder my mistake .
Emre i saw you working on the car but it looked like you had your hands full so i didnt want to hassle you ( been in those shoes), .
Snowman , i am a regular at the meetings ( not this one though even though with race brakes their should be a good one) . The rex club is pretty good especially the motorsport part of it as you will find they are all like minded poeple with very few fools , thats why im still their . I usually race an ol' VL commo but have been using the RS lately . Our next event is at sandown or winton , if your keen on some more info pm me.
adam.
I also thought VicSAU was getting ready for track days ? , if you guys are stuck i can point you in the right direction to meet the cams requirements.
Adam,
You should've said hi... I had parked the car for an hour or two just to watch some action, but went back to it later in the day to eliminate a couple of possibilities.
Anyways, it turned out to be a blown inlet manifold gasket.
Jack, thanks for lending me your AFM mate.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
