Hi all! As topic reads I am an owner of a 95' Skyline R33 Gtst. Bought it 'bout a year ago, was and still is fairly stock. mods so far is:
* 3' turboback exaust
* Greddy profec b boost controller
* apexi filter
Also changed the coilpacks and plugs not too long ago.
So anyway to my problem. Always since i bought the car it has had the famous flutter sound (off throttle) which bothered me some, and the old owner had the Ebc set at 1bar
(14.5 psi) in high mode which I know is to much for the stock turbo to handle.
Experienced what I Belive was R&R at a point when the Ebc was set to only 0.75bar. (11 psi)
Been driving with the Ebc controller off for some time now, no more retarded timing. So with the controller switched off I get 0.64-0.67 bar.
(9.5 psi)
I decided to inspect the BOV to see if I could find the cause of the flutter, suspected it would be blocked, I was right. There was a metal plate in the shape of the gasket in between with some red goo around. Removed it and replaced with a new gasket and went for a drive, now the BOV opens and air gets released, though I could hear a high pitch whistle sound around 2500 rpm with 1/3 throttle applied. Boost still went to 0.64 bar.
Now more recently though the car feels really slow when I go full throttle it's holding back, like I was towing somebody kind of that feel. It dosen't missfire or anything just dosen't have that punchy acceleration anymore, but when cruising on the motorway
and I give it some gas in higher gears it pulls fairly good but boost only goes strong up to 0.44-0.46 bar. I can push it so it reaches 0.52 but thats not until 6000+rpm!
Can it be a boost leak? or clutch maybye?
Any advice would be much appreciated!
Cheers!
Edited by KLA33E
https://www.sau.com.au/forums/topic/458500-r33-feels-very-slow-lately/
Good thing you removed that metal plate blocking your BOV. For your issue, it could be your boost solenoid not opening (you have EBC), BOV leaking, leaking somewhere. Or maybe you were used to having your car with higher boost, and now it is in a normal range.
Did u set the plug gap to 0.8???, at 14 psi the spark would be struggling at bigger gaps. But prob not so much at 10psi.
Also wondering if your BOV is partially stuck open?
Hello! Yes the plug gap is actually 0.7mm, they regap them from factory (also checked this). As for the BOV I think that might be the case actually. Sometimes I think I can hear it bleed off when still on throttle.
I have Ordered a new Turbosmart Plumb back BOV. (BPV) to see if it will help.
Btw i've heard that the original Nissan one does bleed off a little at throttle to recive a more linear powerband. Do you know if thats true?
Edited by KLA33E
    • Maybe but doubt it, when I jacked it up it was creaking in the j arm again. The inners are all good, I inspected them. Remember that also it did fix the problem but temporarily.
    • Could be the other bushes. The inners.
    • Once you lose the adjustable bushes, you have almost no adjustment at the front for anything that matters. You can only wind so master caster at the front, and ~7° is fine. You won't have choice of front camber. If you only have rear camber arms (ie, do not also have adjustable upper tension arms), you shouldn't change their length very much, because you will introduce bump steer. And, you will struggle to find a workshop that will be capable of doing all the adjustment work necessary to simultaneously achieve a decent rear camber number, get the toe right, and minimise bump steer. I would guess there's probably 8 hours of work there. So, stockish rear camber is fine. Although, keep in mind, that stock camber, by number value, does not mean stock arm length when the car is lowered. You will need to lengthen the RUCA to get back to stockish values and that will require the tension arm to be lengthened a little also. Without any other guidance, any change made to the RUCA should have the 2/3 of the same change made on the tension arm. But that is only a rough rule of thumb and the relationship might not remain linear across a wide range of adjustments. And it might not also be as close to minimum bump steer as you could achieve if you did the bump steer measurement and adjustment properly.
    • Well it does have a motor with the same DNA as an Accord V6 motor. The J30A is a successor to the Tiger rice cooker C32A motor found in those cars.
    • FD RX7 I would probably marry if legal R32 GTR is toughest NSX looks like it's made from leftover Prelude and Accord bits
