Hi all! As topic reads I am an owner of a 95' Skyline R33 Gtst. Bought it 'bout a year ago, was and still is fairly stock. mods so far is:
* 3' turboback exaust
* Greddy profec b boost controller
* apexi filter
Also changed the coilpacks and plugs not too long ago.
So anyway to my problem. Always since i bought the car it has had the famous flutter sound (off throttle) which bothered me some, and the old owner had the Ebc set at 1bar
(14.5 psi) in high mode which I know is to much for the stock turbo to handle.
Experienced what I Belive was R&R at a point when the Ebc was set to only 0.75bar. (11 psi)
Been driving with the Ebc controller off for some time now, no more retarded timing. So with the controller switched off I get 0.64-0.67 bar.
(9.5 psi)
I decided to inspect the BOV to see if I could find the cause of the flutter, suspected it would be blocked, I was right. There was a metal plate in the shape of the gasket in between with some red goo around. Removed it and replaced with a new gasket and went for a drive, now the BOV opens and air gets released, though I could hear a high pitch whistle sound around 2500 rpm with 1/3 throttle applied. Boost still went to 0.64 bar.
Now more recently though the car feels really slow when I go full throttle it's holding back, like I was towing somebody kind of that feel. It dosen't missfire or anything just dosen't have that punchy acceleration anymore, but when cruising on the motorway
and I give it some gas in higher gears it pulls fairly good but boost only goes strong up to 0.44-0.46 bar. I can push it so it reaches 0.52 but thats not until 6000+rpm!
Can it be a boost leak? or clutch maybye?
Any advice would be much appreciated!
Cheers!
Edited by KLA33E
https://www.sau.com.au/forums/topic/458500-r33-feels-very-slow-lately/
Good thing you removed that metal plate blocking your BOV. For your issue, it could be your boost solenoid not opening (you have EBC), BOV leaking, leaking somewhere. Or maybe you were used to having your car with higher boost, and now it is in a normal range.
Did u set the plug gap to 0.8???, at 14 psi the spark would be struggling at bigger gaps. But prob not so much at 10psi.
Also wondering if your BOV is partially stuck open?
Hello! Yes the plug gap is actually 0.7mm, they regap them from factory (also checked this). As for the BOV I think that might be the case actually. Sometimes I think I can hear it bleed off when still on throttle.
I have Ordered a new Turbosmart Plumb back BOV. (BPV) to see if it will help.
Btw i've heard that the original Nissan one does bleed off a little at throttle to recive a more linear powerband. Do you know if thats true?
Edited by KLA33E
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
