Hi all,
Apologies I know this has been asked before but getting nowhere...
Just changed timing belt, and replaced all accessory belts at the same time because I had some squealing at startup. Now, though, it's REALLY bad, and won't go away until I've done a couple of minutes of driving, then rev'd beyond 3,000 and let off the accelerator.
All new belts, various degrees of tension (but fairly tight for what I'd like).
How have people solved belt squeal?
I've had this issue with several stageas now, and I don't know what the common element is. I suspect it's glycol on the belts from filling the radiator. VERY frustrating! I've had the car back from workshops after 100,000K services and it's had the problem; I've had an engine rebuilt with new belts and same issue; my friends cars have it bad... pulling my hair out with this one.
I've tried:
- spraying water on the belts, both stopped and while running
- spraying water/detergent on the belts, both stopped and while running
- brake/parts cleaner (good old carburettor cleaner, dissolves most things)
- tightening belts
- loosening belts
- changing engines (not to fix belt squeal, but it didn't help)
- rain dance
So annoying, after doing so much work over the weekend to replace timing belt, to then have to drive around in what sounds like the loudest mouse choir on wheels.
Any ideas which I haven't already tried would be welcome.
cheers
DaveB
https://www.sau.com.au/forums/topic/458502-annoying-belt-squeal/
when i was working as a tech a technique we used was slight emery tape/sand paper, and lightly apply to the grove section of the belt while running, but it would be slightly harder on our cars due to the viscous fan, so may want to take them off and give them a very light going over.
other thing you may want to check is your turbo nuts to make sure the turbo isn't loose i know this can cause a similar noise to a loose belt but thats obviously only happens when on boost.
if not double check belts and make sure they are the correct sizes for the car.
just a couple of tips. but without hearing noise it can be hard to diagnose and do fixes.
Thanks Michael. I suppose I could record the noise but if you just imagine a really loud belt squeal, that is constant. Revving the engine makes it louder. If I spray some water on the belts at the moment, it will go away for a few seconds.
The sandpaper on the grooves sounds interesting; it would flatten out the peaks a bit and make the belt sit potentially lower. I might give that a go. I plan to get some CRC brand belt grip and try that tonight. If that fails (and I'm thinking it will) then I will try the light sanding. RB25's have a viscous fan too so I might have to take that off again.
I used Belt Grip on my Commodore once, it just made a mess of the bay and caused the engine to start throwing belts. Never again.
I'd recommend trying to find the core issue. When you say you replaced the engine did you carry over any ancillaries from the old engine, like idler pulleys etc?
  • Like 1
Thanks Hertz... Commodore's have serpentine belts don't they? I don't think they're meant to take belt grip? Probably my experience will be the same as yours knowing my luck however... thanks for the warning
Yes, the idler pulley was probably carried over by the workshop.
However, the squeal gets worse/comes back when either:
- AC clutch engages (AC belt)
- fan comes on (alternator/water pump belt)
- I turn approaching full-lock (power steering belt)
ie. all belts are affected.
I have 3 stags and they all have done it at various times. It's an RB thing, all part of Hirohito's revenge.
Just do one belt at a time.
Thanks, perhaps tonight I'll pull them all off again, and then try new and old one at a time, and run it as I add each belt to find out if it squeals.
Well, just finished replacing the valve seals and replacing all the belts. Pulling them all off and testing them one at a time I think is the way to go for me in the future. It's finally quiet! Water pump/alternator belt was the worst offender. Had to put a fair bit of tension on it. Can't quite play low E on it so hopefully it's not tooo tight.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
    • Besides packing it, you can also fill your pump through the oil filter inlet port. After cranking for what felt like an eternity without pressure, i fed a tube in through there and filled it with oil. Cranked for a few seconds after that and had pressure.
