1998 Nissan Skyline r34 25gt-t
162xxx kms
Rego paid until Mar 2016.
Very clean car all around, always serviced on time and regularly.
Car has very clean interior and well maintained engine.
Have receipts for all mods/servicing.
Features of the car include:
-Full factory optioned Nismo/Altia body kit
-Factory optioned xenon hid headlights, can adjust light level in car.
-Brand new Century 50 CCA battery
-Brand new exhaust manifold gasket,studs.
-Brand new turbo gaskets
-Blitz turbo timer
-Cyclops full Alarm system
-GoFastBits G-force II boost controller
-Blitz turn-flow front mount intercooler
-3' custom stainless steel dump back exhaust system, 100 cel hi flow cat, hot dog resonator, subtle muffler.
-Apexi power fc ecu with new version hand controller.
-NPC organic heavy duty clutch kit
-Alpine double din headunit, Bluetooth, USB, hands free, ipod connect etc...
-Kicker 6' speakers all round, tweeters and kicker ES 12' sub
in boot.
Car was tuned by Sam at Dr Drift at a safe 9.5psi making 197rwkw very smoothly.
Car is in great condition and runs amazingly first to see will buy.
Lowballers will be ignored. Serious buyers only.
Feel free to come for a test drive.
0402229303
Cheers, Luke.
  • Like 1
https://www.sau.com.au/forums/topic/458519-r34-25gt-t-fs-in-taylors-lakes/
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
