Barry believes it, with E85. RB26s with 98 make about 340-350 with GT-SS.
Im not sure of the state of the car itself, but fair level of supporting mods to get it up to 400 i thought. Solid fuel pump setup, big exhaust (and all the GTR conspiracies that come with twins), clutch... Im sure there is other stuff i havent thought of.
i'm just going to throw it out there... but has anyone considered that the RP dyno might just read lower than others?
(not that it matters in any case)
It's all marketing...
- make the dyno read low where people have money to spend for more upgrades
- make the dyno read high where people are a one-time show so they can advertise & bring in more business
illuminati
Yes but not nearly as fun as paying out hub dyno people for thinking they have more power than they do
  • Like 1
I can't see there being an issue with it hitting 400 on e85... it would be absolute max but should be possible
Yeah either way I don't really care about the top end power figure; never have. Within reason (obviously I'll be shitty if it finishes up at 250), but it's the midrange and linear torque I want here. I judge this by acceleration and seat of the pants alone.
Will never forget the '450rwkw supra' on e85 at the chasers dyno day rocking up with skinny 17s on the back did a bout 10 runs to try and beat the 2 falcons :P
Yeah the falcon 4l turbos are quicker than the 5l v8s (at same or similar power) because of the power curve pretty much constantly on their max power output whereas the v8s wind up. My power on a 6 pretty much runs 10s
Can't beat dat dere instant torque and response on the 8 doe
Whats eta on your gtr?
Edited by UNR33L
As soon as Barry gives me an ETA I'll multiply it by 2-3 and let you know
Waiting for some parts at the moment apparently
Doing some oil supply bulletproofing
Only has to be 50% of value for write off I thought? 2k excess sucks but that's nothing compared to what i'd get paid out if needed
Daily driver but I think on policy is only 10,000km a year
Edited by UNR33L
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
