Anywhere but centreline
One sour experience, many moons ago = Never again. No one is allowed to use that workshop on your watch.
Good thing you never went to Rajab, or the last few years of RE Customs
Centerline.... Can't go wrong. Your side of town as well.
As far as Toyota boat specialist... 612 Autoworks is a garage business doing lots of crowns, cressidas and chasers.
my preference is to take it somewhere use to dealing with cars that aren't worth about 15% of the value of my car
Ie ya standard young 'enthusiast' shop
Edited by alr33x
MaseratiOz forum is thata way --->
  • Like 1
Should I reccomend a shop that tried to BLATANTLY rip me off, and also my mate just because they work on some old POS mazda race cars?
So, as mentioned, go to centerline where they are used to working on race cars worth about 3 times as much your lexus
  • Like 1
Did good work on my pulsar a whole bunch of times and did a proper job with the Gloria.
Maybe they didn't like how you carry yourself. It's west side after all. Next to Hells Angels HQ
Well Dezz said its shit so must be shit.
Shoulda known asked in the wrong place ere
Not worried about race cars etc but I've seen how the workers treat every car the same lexus, skyline, Audi, VL I'm not interested in those places
From what I've seen / experienced:
RTR = Low by a few percent
Racepace = Low by a few percent, and not an accurate torque figure (its calculated via road speed, with no tacho input)
Chasers = Fairly Accurate
Trent = High by approx 10%
Thats why when I had an RTR tune at 255rwkw I'd tell people "255, so about 270 on trents for comparison"
At the end of the day though, who gives a crap what the figures say... What you want is a Pre-Tune overlay on the final printout so you can see the difference in the shape / area under the curve.
And lots of people always seem to forget that when you roll out of the shop, if you're actually running the same tune / timing as your max power run then your car MAY last until the end of the week, or until a slightly suboptimal batch of fuel / hot day.
RacePace usually give you a max power run just for potential then dial it back for safety; pretty conservative tunes IMO
But most tuners who have been around a long time are these days, unless customer requests every last kw - it's not in their interests to have customer cars shattering pistons
My mates car with the same mods as mine made 297kw on 98 at chasers with mine beng 10k less at trents.
We threw it on the dyno at dr drift and the afr's were 14.5 and climbing at 4000rpm when we pulled the run
Chasers CAN be good, but if they dont know you.......
That's great, you want to recommend them based on your experiences, I'll tell people not to go near them because of mine.
What kind of expert charges $X (overpriced at that) for a service, then tells that customer their setup is a mess, and asks who set it up... That's a quality workshop.
  • Like 1
Hate to break it to you dude, but they ARE all the same...
Especially a toyota with an L badge
As I said centerline work on cars worth all sorts of coin including high end race cars with rediculous suspension setups
Not really all the same big difference jumping in a 20 year old Nissan with ya dirty clothes and a car with white leather
But anyway
An apprentice driving a 10k car or a 100k car
I don't see the same same approach myself, not to mention IF something goes wrong the shitty shops will probably not even pay to fix
Edited by alr33x
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
    • So, starting with the rear brakes. They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
    • I clean my wheels every time I wash the car, I also clean the barrels, the only product I use on the wheels is truck wash and a pressure washer, followed by (inset your chosen name brand) wash and wax, time per wheel is probably 2 minutes total, cleaning the barrels is easy with one of these microfibre thingies on a stick from Sabco, they're also great for getting in between the front guards and body, and tight spots in the engine bay
    • An updated post here. Sounds to me like there's definitely a bit of sketchiness here.  Old mate with 10 rusting Torana's in the front yard might be more who they're focussed on. (For right or wrong).
