need to get a valve replaced in a Tyre when I get home, any idea on how much?
it either the valve or the rim...
had a slow leak but the tyre was getting old replaced and the slow leak still there, so assuming valve or fked rim.
Last time I got a stuck valve replaced on the skyline it was free... They came out with their valve replacement tool, took off the valve cap, unscrewed the valve, screwed a new one in... Took 5 seconds, didn't even jack the car up or anything. Just replaced the 10psi of air that it dropped during the changeover.
If its the valve stem not sealing though, then thats a tyre-off job.
Also, if its the valve, then you shouldn't be losing air if you've got decent valve caps on.
Have a look at the valve stem when you get home and see if it looks new, a lot of tyre shops will replace the rubber stem and valve when they fit a new tyre.
Def not replaced.
Should probably look into some blue rays valve caps
interesting...but prob cheaper to buy a replacement ute.
could be the seal around the valve or a bunch of things, last time I got tires on the 200 they checked and the vale steam steal was cracked and perished, so it got new ones at the time.
and yeah they cheap and nasty plastic caps
Replacement ute doesn't come with a Free Instagram account and a boyfriend though...
Buy the Blue Rays valve caps, you can have all of these things and more.
LMAO!!!!
So last night I got some immunisations and threw a post up on FB taking a jab at Anti-Vaxxers... This morning I spot a Facebook Message sitting in my "Others" folder from some ransom person (friend of an international friend) saying "You won't be laughing when your children become retarted due to the governments lack of due diligence!"
1. Yes, she went out of her way to send a message to someone she doesnt know.
2. Yes, she's in an idiot.
3. Yes, she's "retarted"
Dat great weather, prime time to go and start enjoying a car...
..shame I blew the head gasket/cracked the block/lifted the head 7000kms after paying 12k+ to get the engine re-assembled last night!
the cycle cannot be broken
I don't think this was caused by you being Greg, I think this was caused by that abortion of a sentence.
LMAO!!!!
Or some aborted foetus's stem cells
Just saying. :D
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
    • Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage.  So your story of tricky pedal setup seems common.    Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line.
    • There's always "MIG it up and grind it back".
