It's not, nor has it ever been, nor will it ever be, cool to drink any beverage from a f**kin jar
Shit no! That would be like following a trend... Might do something original instead like collecting nikes :P
If anyone is keen going on a spirited drive tomorrow morning south east with a mate that just brought a lotus.
Hit me up if you are
There's a meet at sky high mt dande tomorrow. Friend and I are going
  • Like 1
Spent entire yesterday removing shit to check torque on head studs. ARP specify 90ftlb.. Blueprint says 80.... Sad
Then checked them...one was 80, some were over 90 and some were WAAAAAAAAAY less, like one full turn of torque wrench off.
Sure is a good day for a drive today!
Well if the head lifted one/some of them have become loose?
I don't usually enjoy watching racing on tv but weather is just asking to sit on the couch with a Kilkenny or 6.
(After walking 5km around a park)
Bought some Asics Kayano Evo today (so f**king melbourne wanker) holy shit these things are absolutely streets ahead of nike. I think a 25 year relationship is about to be tested...
Are you running in them or just casual? Have been using Kayanos as running shoes for years, updating them every other year. Such a good shoe. I wear them as casual / around the house for their comfort. It's like Jap cars versus Italian; Nike have the style, but the execution and tech isn't there.
Actually this brings me to a question for dezz.
Michael, as someone who buys limited edition Air Max 90's, are they of the same half-assed qualty as the standard stock or do they actually make an effort for these?
(The paint job in particular, which I understand won't be hugely obvious on your red and blues ones)
Dezz phillip island on the bike awesome fun, crazy speeds when you're going around a corner and look down at the speedo
Did miss not having a front windscreen though, 'sports' bike clearly more ideal for that sort of thing..
Edited by UNR33L
  • Like 1
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
