So there was this block built off the plan in Sydney and it took 5 years to complete. In that time the value doubled and the scumbag developers used a contractual clause (contract dissolved if not finished in 5 years... intended for the purchaser to use, not the developer) to weasel out of all contracts and sell to new buyers at the increased value. A judge found in favor of the developer (as the case hinged on the developer deliberately slowing construction to exceed 5 years and this could not be proven beyond speculation) and everyone lost out.
anyway.... and this is mainly for Birds.... I had a look at the judgment... check the names of the plaintiffs
https://www.caselaw.nsw.gov.au/decision/560e162be4b01392a2cd1569
  • Like 1
Ouch & lols at the names.
Going to Singapore at the end of this month
Tips for tourist shit to do pls
I don't particularly like Asian food so don't bother with all those suggestions
When you going? If it lines up with my r&r I'll gate crash like I did Birds' Singapore trip haha
  • Like 1
Judas
Horrible decision by the judge. Massively unfair.
  • Like 2
f**king scumbags
The plaintiffs that is
Wouldn't have been the same without you - must go back.
  • Like 1
Singapore will make you like Asian food
It's like the two hat restaurant of Asia
At least try chilli and lime stingray while you're there
  • Like 1
Sentosa island is good. Marina Bay Sands okay. Their zoo. If you like shopping for overpriced designer shit...Orchard Road precinct...
Check if your trip lines up with Halloween cause universal studios on Sentosa Island does Halloween nights, which goes off. There's some night clubs there that make a big deal of it too, everyone dresses up in Halloween costumes.
Judas
Haha I knew that would rustle a few jimmies
That's exactly the shit I like. Will check it out
I am there for Halloween but I'm going there for a wedding which is that day
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
