Yeah I think so, looked that way. But surely it's a weight saving.... Everyone else may as well do it
yeah the evo I was looking at a week or so ago had that done.
the small amount of weight saving there was massively offset for the piping and 3x the amount of coolant. but the extra coolent did also mean less air flow was needed for a single lap dash.
Geelong bitter is where it's at.
Don't care how bawler you are, $4.50 jug is hard to pass up. Sometimes you could taste a hint or cornchips
Many happy night in the 90's from GB dollar pots
That's because Singaporeans ARE people from the rest of the world
Were*
Now new China
This. PRC's are takin over the island. Even OG SGers are gettin all xenophobic about em.
We'll have to agree to disagree...I haven't driven a 2 litre that's wowed me down low and held it through the rev range yet. Evos especially with their weight disadvantage - feel like you have to give them heaps to get them moving, and a Skylines are bad enough for that.
A45 AMG. 2L. Froff.
Lol his A5 WAS a piece of shit... like everything made by Volkswagen
Eat a bag of dicks kent.
This is likely because of the cornchips eaten by the person whose beer vomit they recycled that shit from
Guess the unwashed masses need to think they can eat like the rest of us.
IN all seriousness Katie wants to go but I want to hold off for 6 months, can see the menu being "fine tuned" a few times early on till they get there.
not that every review won't be full marks no matter what they serve up...as if Heston came up with it and must be smarter than all us so lets give it full marks so no-one clicks we did not understand it.
SG taxi drivers got a mad hate on for them even though they are half their fares. SGs have been forced out to the fringe. One driver warned me it could happen to Australia too
Then I warned eastern suburbs Melbourne and VWL and yeah...too late. Rekin's ego suffered many dents at the hands of 18 year old cashed up Chinese princesses owning the auctions.
  • Like 1
Understand food lol...that's what's wrong with all you fine dining cocksuckers...does it taste good? No? Then its shit food. f**k the experience.
China will own Australia soon enough so we'll be the ones invading what will be their country
  • Like 1
Now now, no need for all that anger just because you don't understand
I mean the generation 0-40
Though I think it's a societal shift brought on by technological change and cheaper material goods rather than isolated to one generation
Even my 59 year old mother can't wait for the next iPhone...had to get a 6S to replace her worn out 6...from 12 month ago.
It's taking a holiday together for the last time before your life changes for ever. Not to mention the fact that you won't be able to have one for a long time afterwards
Not a difficult concept really
  • Like 1
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
