Mohsen you should buy a vl turbo
i really want a calais.
Good man just crazy busy been a huge year, long days every day start taking a toll though
Hows things on your end?
not too bad, also crazy busy.
inconsistent months mean im stressing, which doesnt help when ive quit the darts haha
leigh, all the nudes.
Yeah man that inconsistent roller coaster thing is super frustrating.
Good ya off the smokes man that shits no good
yeah anger has peaked though.
Saved money on smokes = More money for mods (or in your case, repairs)
approx 3 months.
just went cold the sphincter of the universe lol.
heaps of $$ saved
CONGRATS PAUL!
Mohsen is one of the few cases where I say he would be better off addicted to smoking than spending money on cars
you wait till i drop a mixtape, make a movie, die of an overdose and reappear and become rich.
So yesterday we were at a playground... I let Orlando ride his BMX through the actual equipment as no one else was there.... confidence built and he was freaking tearing it up WTAC style.
Another kid came along and I told Orlando to stop. He didn't listen and threw down 1 final lap... On the final suspension bridge (pictured below) he came round the corner from the right and ran straight into this kid... BOOM! Kid goes down like a sack of potatoes and Orlando & his inertia keep moving forwards. Orlando flies under the railing on the side rolling off back first to a ~5' drop.
Absolutely shat myself. was totally expecting mad injuries.
As he flies through the air he reaches out and grabs the bridge with one arm and somehow holds on. He hangs there for a few seconds till he stops swinging then drops onto the ground like a f**king BAWS and walks off.
PROUD DAD MOMENT
SO your saying your son was hooning with no license, had a hit and run and did a runner down a drain.
irresponsible parenting at it's worst.
should call Child protective services.
Lol I was totally getting all the "bad parent" looks
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
