You can't even lock someone up who threatens to do stuff. Even an intervention order needs a valid reason, that can be challenged and you can be sued for allegations if it doesn't go through.
Have to agree there. Ironically less chance of them getting away with it or worse, getting fked up by the perpetrator.
Laws are powerless to do shit against the real crims and the crims take advantage of this.
more lols at my expense
Found out why my head was lifting under boost, on cylinders 2, 3, 4, 5 and 6...
.. the ARP2000 head studs I bought from [removed] many years ago are clearly not ARP2000 head studs for a RB25, and are 35mm longer... than genuine ARP2000 head studs. Also whatever they are is 1/2 instead of 14mm.
WTS ARP Head studs...suit.... something?
oh I own something sounds perfect for me.
Funnily enough the thread on them was much the same, it was the bit in the middle (dunno the proper term) that was quite different. It was also twice as thick and yeah, very confused when they were 1/2" instead of 14mm.
Headspec didn't think to check them, because I had every other decent part and ARP Studs are re-usable and it's a safe assumption that RB25DET studs would be used in it.
Well, apparently not a safe assumption at all!
This is where I'm grateful of Barry's OCD; I feel like that's something he would check, even if that check was a randomly scribbled note on a whiteboard somewhere in the workshop lol
