I don't have a driveway...
Dare I organise a working bee to get this shit done? Who would properly come? It would probably have to take place at Scotty's who at least has a hoist for dat dere lower car onto engine approach.
"The Birds and the bee" - help get me back on track. Free bbq and severe amounts of alcohol supplied.
just remember to give the booze at the completion of work.
the amount of jobs we have started and had to finish next morning as we got on the piss
  • Like 1
But what do you do when a rumour starts that the ecu is considering a transfer to another vehicle and neither denies nor confirms it?
Ask the ecu to draft up a role description & put out a feeler to find a piggy-back to take some of the load.
  • Like 1
What's your assembly PB?
I guess we could try for some sort of time setting record; that sounds like me to choose hijinks over getting the job done properly
no shit, im f**king great at pulling shit apart but no good at putting back together, which is why you have miguel and sir odium. those dream boats are f**ken guns.
we could even kidnap borci.
Is there such a thing as too many hands? I see a lot of drinking and hardly any work getting done, or having to ask 8 people where an unlabeled part is because we tore the engine apart zombie horde style lol
The more people present the less accountability per team member. Which can result in a bigger pisstake for something which needs to be taken seriously lol
Looking forward to the Sandown day in January, do you know when we need to register by / when/if it will become full?
Just ordered a new bodykit which is getting painted next week. Time to upgrade the brakes, exhaust and wheels next month as well :cool2:
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
