For all the refugee & good food hating bigots in the house.
Here's a story on some good friends of mine who also happen to make the best phó in town
http://m.theage.com.au/victoria/hien-vo--from-refugee-to-restaurant-owner-the-woman-who-brought-us-bowls-of-pho-20151119-gl3kte.html
You mean, only Alex?
http://www.speedtest.net/my-result/4847713528
yay house internet has been dropping in and out all week and today has been choppy at 2mbs. login into the router and says its 5.7mbs...
Its been ok for a few weeks before this, and then will be bad for a day or 5 then be back to normal. been talking to internode on and off throughout the year about it and ive replaced the line filter with a normal cable, and the only other option is to replace the router. I borrowed my dads old ADSL2 modem/router and found out its not compatible with iinet's network :rolleyes:
the fritzbox is a $300 router than ive never had any issues with, other than having to reset it whenever speeds slow down. im not going to replace it just so internode can lodge a complaint to telstra/optus whoever. changing to cable from optus or telstra would double the internet bill and i'd lose my $20 a month mobile SIM.
The least I paid was a bit over a dollar
Now it is exactly on par with unleaded...and if unleaded goes up it does too
Except when unleaded drops it doesn't drop
So much screwage
Drive to phillip island was fked - planned it so my last fillup would be in Cranbourne - pump not in use. Travelled west to Frankston to get it - waste of ~10 litres
I DID have jerry cans lol
By the time I got to PI and drove around on the Saturday I had 3/4 in the first session. After issT two sessions tipped one can in, then at end of the day I put the second one in and made it home with 1/3 a tank left or something.
E85 is bad enough on economy let alone tracking it :(
That's thoroughly retardsd...I would have taken 6 at the most and 98'd it until I got to the track then switch.
The United in San Remo really needs it; it would get more use than most E85 bowsers in the country. Cranbourne being bone dry is evidence of this.
yeah thinking must have been a 2 day track session for 22 jerry's
but still difficult.
I want to convert to E85 next year however also moving to the country so nearest servo 100 km away, going to make life difficult
time to conver to new tow rig with extra tanks
http://www.sau.com.au/forums/topic/460581-fs-bmw-335i-e92-prior-design-widebody/
$10k for wheels and tyres?
over $1k to fit a rear diff?
$30k for widebody and re-spray.
wants 40% back on what he paid for mods + value of the car?
i feel sorry for this dude.
not to mention you can get an M3 of the same era and kms for the same or even less money. I wonder which will depreciate more?
Funny shit on the road today.
Some dickbag motorbike rider clearly had some form of beef with a dude in a car.
We were driving down the road and he was sitting on his chopper show bike right up this cars ass, then his mate that was waiting for him pulls out of a parking space on a dirt bike and sits in front of the car while old mate Phaggot Mc Showbike moves beside the car.
They look at each other and dirt bike brake checks the car while showbike turns into him, forcing the guy all the way onto the wrong side of the road and nearly into incoming traffic....
A 3rd bike was there, unaware of what was going on, but as so many idiot motorbike riders do, was sitting in the cars blind spot with that whole moron "if he hits me it's his fault" attitude.
Dude narrowly missed being run over by the car, and then the oncoming traffic.
Crazy stupidity all round.
I would have called the cops but the 2 offenders didn't have lisence plates :/
fark, 90k of mods? lol
also maybe you should sus out other ISPs if yours aint doing shit bout that shit speed
Edited by UNR33L
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
