how was everyones week end?
Spent most of yesterday arvo chopping out rotted wooden support beams out of the bottom of a fiberglass boat. So I'm itchy as fark today.
The day started with "Lets replace the soft plywood floor" and escalated into a fully stripped hull and plans to replace seating / supports / wakeboard rope riser pole, etc
Fibreglass is good for you
Probably
Wakeboarding is amazing, will be worth the fiberglass impregnation once finished Simon...
Had my last hens party ever on sat
Dad's birthday in the evening
Slept in Sunday - doing nothing on some weekends is underrated
i never got into power water sports. its the smell of crappy fuel and people hosing off their boat after a morning of fishing. such an inefficient form of transport. jet skis ruining a perfectly quiet beach. me failing miserably at knee-boarding on an awkward ex gf's family trip to eildon. having to read speed gauges in mph.
Knots is where it's at
Also, that smell of fuel around a 2 stroke outboard or 350 inboard is possibly the best smell in the world
I reckon wakeboarding is easier than kneeboarding, was up first try on a wakey but kneeboard took a few goes
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
