Apparently the RB hypergear turbos are sorted... They reckon the VQ needs more research.
Seems to be any setup that deviates from what they were designed on has some probs. Noticed it a lot when Tao was putting his Turbos onto the SR20 when he had the S14, things that worked fine in one setup just did not work at all on other setups, even his own cars.
Not really surprising that others have issues when their setups are different. (like my RB28 :P)
For a hiflow on a RB you can't really go wrong with HG though. Then again, are there real options besides GCG for that kind of thing?
not sure about Hi-flow options. but people will always have relatively high expectations for a product when the main advertising point is so specific: "300rwkw on stock RB25 @25psi by 3200rpm" or something...
The only thing that ever bothered me about Tao's power claims, without triggering a hub/wheel shitstorm, is that he found a happy dyno in Trent's hub dyno, which has allowed him to make such claims that no one else around the country could replicate at their own tuner...unless they went to Trent.
No turbos produce that much power with that response on a 2.5. I believed the response was possible (though some argued about different ramp rates etc.), but the power figures for such responsive turbos had to be called into question.
But customers are also dicks, having an exact power figure in mind that they want to achieve, because they like the sound of the number and have no measurable need for that much power, but are scared their dick will look small if they didn't get the omg300kw matched up to federal 595s that made them slower off the line than a stock Skyline.
When I bought mine I didn't care too much about power numbers, just wanted a responsive turbo that has more grunt than the factory one and I got it; that's probably why I'm happy with mine. All these idiots bought G3 turbos that come on song at 4500rpm and make 300+, nek minut they were in the for sale section. Best advice I got was from some guy selling a high flow who had "upgraded" to a 3076 and said he wished he kept his high flow on there cause it was more fun than his current setup. Listened and here I am! Plus I drove Tao's car with 320rwkw and all it wanted to do was eat the curb at 4500-5000rpm...waste of power.
happy dyno
Strange, the people I've seen get tunes on that dyno, and Racepace dyno, and Springy Motors dyno, were all within ~1kw of one another.
People need to setup their engines to the maximum tractive effort supported by their tyres. Anything else is slower unless you're on the track and frequently 80-200+ kmh which is the only time you will start clawing back the car lengths you lost to the guy who makes 270rwkw when you make 500rwkw.
The limit of current road tyres on the back of your average JDM car is about 280rwkw anyway. Wanting that extra ~10kw is just dumb. Every time I drive anything else and I can just floor it in the hills and have fun in it I have ragrets. I had more fun hooting around in a MX5 on BC's and tyres with the roof off in a sunny day with a pretty girl than I reckon I've ever had in a 400+rwkw R34.
Hence a lot of people don't get the appeal of an 86 until they drive one. It's a car you can thrash with little consequence that doesn't lose much speed in the corners, even on factory tyres.
thats just like saying buy a shitty ninja 250 road bike and enjoy it through the corners, not a 600 or 1000 :P
strongly disagree! still fun but 600s or higher are more fun :D
Edited by UNR33L
My car made as much power as any his highflows and was more responsive. It's completely possible.
Where Tao's claims deviate is the non stock manifold he uses and the timing/boost he demands is poured in.
Yeah but you can have fun with a 250 in the corners...look at the dream boats doing crazy laptimes around PI with a 250...granted race bikes but still. They are nimble as fark.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
