Strong return post - where you been hiding Toby? Also, mad invite for Burgers :domokun:
Oh yeah forget your residing in Melbourne now, next time! I did invite you to yumcha that other time!
Hahaha Toby outta nowhere!
Logic too twisted so had to post
  • Like 1
Isnt it for every Up proclaimed there are dozens of Downs unmentioned? :P
Good to see investment into mining/exploration.
Yep, just like gambling, which is what it is. But this is a massive up that is happily wiping out my only significant down which was during the GFC. The point is my GTR has potentially been paid for. Mine on!
  • Like 1
spoken like a true boardroom warrior
  • Like 1
ok so senario..
i'm invited to my soon to be brother in laws bucks.
my missus and her sister expect a full run down of the night,
i don't want to lie,
So the socially acceptable thing is for me to turn up to the afternoon activity, swing by the early dinner...then vanish,
It all depends, is your wife going to let you take your balls out of her purse for the evening or will she hold onto them?
  • Like 3
Not to move the topic from Martin's handing in of man card, but
VWL hypothetical: if you had 100k (I don't) to spend on a car right now, what would it be? Any remainder can be kept as cash, but as a hypothetical, cash is relatively meaningless to you / you already have plenty.
would finish pulsar.
leftovers on gloria.
no cash remaining. mi goreng for dayz
also: that has to be the most retarded oil and coolant setup outside of europe. everyday i slowly get closer to understanding why toyota people hate working on nissans (except toyota celicas)
Try to fix R34
wait for more budget
Option 1: Buy a $100k car here
Option 2: Buy the identical car for $60k overseas (Europe or USA), spend the remaining $40k on a holiday with said car thrashing it everywhere and giving zero fks about speeding fines. If licence gets suspended, move on to next country.
  • Like 1
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
