We just work flexible hours at work. Come in whenever and leave whenever. As long as the job is done NAB are happy for us to do whatever we want. Funny thing is most of us end up working longer hours because of this.... Sneaky NAB lol.
When OT is on offer we just come in/work from home/go to a business banking centre and do what we want then tell them. Some people literally do 40+ hours of OT when it's on offer
That's the way a company should be; it's the single most efficient organisation plan and hardly any embrace it. Puts responsibility for productivity and output right into the hands of the employee.
other than our call center that how we work.
Surge tank if your worried about fuel starvation... Not needed unless running semi's on track I reckon (depending on tank design)
But knowing SAU, Mohsens car will catch fire at the fuel pump and Greg's will still starve from fuel when exiting his driveway
I went through 2 x 040's and a walbo 255 when I had a bad batch of fuel and didn't realise that was the cause of the deaths... grit in the tank for like 9 months....
Cleaned it, then went to a Walbro 460.... E85 compatible and it's been lovely ever since.
Walbro's are quieter and smaller in size than the Bosch's... go the Bosch and hard mount it poorly in the tank if you want the whine. because racecar.
Walbro 460.
wire it properly
overkill the shit out of the wiring
Good for the amount of KW on E85 you'd want before it becomes a laggy piece of shit
I think you should listen to Greg's suggestion, he sounds like he's on the right track
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
