nah, gonna have her contribute rent/board/whatever you wanna call it though.
cheap obviously, we were thinking like half the price of if we were renting somewhere together, e.g $400 per week would be $200 each, so if my place would fetch $400 a week she would happily contribute $100 a week.
She's saving for her own place too, so better off that way rather than renting somewhere else.
$100 a week to live in a furnished house with just the two of you? That isnt rent, thats like living in a shitty bungalow in Sunshine North kind of money. I'm wondering if she was interested in moving out or milking her bf for all its worth :P
Better get that pre-nup yo
It is interesting that only 6 cars out of 120 went faster than 1.25 though as well..
there is that, anything under 1:30 is a good effort
that said sandown is highly forgiving of horsepower, it is basiclly 2 drag strips with a couple corners connecting.
I'm surprised the two of you fit
Ghetto version of corner weighting.....put another body in the passenger seat.
those 2 runs were what put me out tho, tried to do them in 1st only too much limiter action and put me a couple sec off the pace.
Lol really? too cheap? I would of thought you guys woulda said the opposite!
hrm.
Mate
Women these days want the right to vote and all that shit...take everything that goes with it.
that shall go into a car mod fund heh
$400? You're dreaming. More like <$350.
Although I haven't seen your place or know where it is. Haha
Haha, That was just my example, after I bought the place agent told me can probably get 360-380
Also got that promotion at work, wasn't quite a 10% rise like I wanted.. a little bit off - now the question is do I bring it up and try and negotiate the 10% I wanted or accept what I got given! #changemanager
the worst that can happen is, they say "no, f**k off leigh, are you f**kin right in the head? cooked flamin mongrel"
Don't wanna piss them off and pick one of the other 2 internal applicants :P
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
