Myself included...as I've joined the ranks of people getting screwed at house auctions
540-590 range
Opening bid 620
Sells for 761
Sold for 600 4 years ago, area has had 27% capital growth, median house price 650 lol
  • Like 1
540-590 range
Opening bid 620
Sells for 761
Why would the range be less than the previous sale price? Sounds a bit off from the beginning...
Yeah, real estate agent got a scare when he called us asking if we had any offers and we said we knew it had sold for 600 previously...he spouted some shit about them being desperate to get rid of it, prolly to cover his ass.
Oil return line to Turbo? I have swapped that already sadly.
I should probably also say that it looks like it's dropping on the front sway/running down the sump.
Can it be anything other than the front main and/or oil pump gasket?
Don't see why they would be load-based however.
What do you mean A4 sized oil leak? Bruh cars oil pressure usually rises with revs, you should know this. More pressure = More likely to leak
If it's coming from the front then it's likely to be Cam seals or Crank seal.
Yeah I figured it was pressure related, but wasn't really sure how more pressure wouldn't just cause something to fail fully.
What I meant by a4 sized, is that the patch on the plastic cover under the engine (under the sump etc) is about the size of an A4 sheet of paper.
Don't know much about oil (of all the problems Ive had this one is new)
Cams all look dry, well rocker covers at least. Nothing is oily above where the Harmonic balancer is, so I figure it has to be the crank seal, but again, don't really know shit and could very easily be something else I never knew about
so ive been thinking of what JayZ passed on to us, and im not sure of his situation.
Did he have bitches, and that theyre not a problem or that he didnt have bitches therefore they werent a problem?
Sometimes it's hard to see a cam seal leaking, usually you'll see it down the side of the lower cover and pooled around the crank. It's all about finding the highest point that the oil is leaking from, oil can't drip upwards after all.
Both
He was saying that bitches present no problem for him, when he has them and when he doesn't.
Are you sure it's oil and not ps fluid?
It was originally gold, and I thought it was trans fluid (Transmax Z is gold) but it was just new oil as it gradually got darker, and the fact all the PS stuff was completely spared. It also gets all over the hard trans lines and where they connect to rubber joiners so I've had many "Ah I bet its just XYZ!" to be found no, sorry, it is not XYZ.
This is what I thought too, the highest oil was on the merge point of the top and lower cover, I can't think of anything else it really could be, hence the post because I r n00b
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
    • Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage.  So your story of tricky pedal setup seems common.    Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line.
    • There's always "MIG it up and grind it back".
