brah i need some tax loop holes / massive deductions hit me with some good tips you accountants must rort somehow
get work to pay cash in hand and hide under mattress?
give it all away to a charity.
I like the Martin needs a shed charity myself, I'm sure it will take some donations.
but what about yours?
My car's was fixed about 1/2 a year ago lol
Prob just never see it as i never go to meets anymore
You talking about tax minimization or tax avoidance lol?
I heard buying investment properties and utilising negative gearing helps. Have a look into this property buying thing.
I'm happy to pay income tax but capital gains is a fking rort. Taking money from what they did nothing to help me achieve, when I took 100% of the risk on shares...yet they wouldn't cover my losses if things went the other way. At least if someone has no income there is welfare.
When does tax bracket step up to 40%+?
Single, no kids that is.
$180k
But don't forget it's incremental.
It's circa $54k flat rate for the money up to $180k and then 47c/$ only for the taxable (after all deductions) income above $180k
CGT is the equivalent of being shaken down for your lunch money
  • Like 1
Really can't think of a better metaphor for it
Except maybe the yakuza taking their cut from a district of businesses to "protect your business" from getting f**ked up (by them), except that the government f**ks your shit up even after taking the money. So really, they are worse than an organised crime syndicate.
How is it any different to earning an income through work? They didn't help you achieve your KPI's and you took the risk by overselling yourself at the job interview. They wont cover all your losses if you lost your job either :nyaanyaa:
They'll give you $250 a week for it. The only thing you'll get from capital loss is savings on capital gains IF you ever make them again.
    • It cost me $2900 all up for a local trailer / towbar place to supply and install. I did think it was a bit steep initially but after all the work involved and seeing the final result I think its well justified.  Hardest part was finding someone willing to customize and fit it up with trial and error basically. Whereabouts are you located? - I had my work done locally in Wangara.
    • Get something that can spray a bit, something like I'd use is a pressure pack for weed sprayer. I use one with degreaser. Spray it on (make sure you're fully covered up, you don't want that shit on you, especially face/eyes). Alternatively, a paint brush will help here as you can brush and work at the stuff quite aggressively.   Be aware, citric acid can eat metal away and will cause it to rust more later. So make sure you neutralise it when done, and give the fresh metal some protection. That hanger, I'd honestly bin and get something like the Frenchy's drop in replacement. The tank, again, I'd look for something else to replace it with. Remember, as metal turns to rust, it means there's less metal there now. So some patches of your fuel tank are likely to be quite thin.   Personally, Id focus on the front end of things, IE, how did the injectors get clogged if they're meant to be after a fuel filter. Then, once the front is sorted, I'd rig something up, even like a small surge tank, and make sure the engine is now running and all behaving. Then I'd replace the fuel tank and fuel hanger and pump. Also, I'd already be preparing to ditch your fuel filter...
    • That's looking great! Are you planning to do things like all hidden wiring with it, or you're planning to have it look more like we'd expect an RB in an engine bay to look like?
    • Haha thanks everyone, I'll take everyone's suggestions into consideration. If I do eventually choose a car ill post it here update on the mods I do.
    • I found the ingredients at larger amounts from a Coffee Shop. 1kg Citric Acid for €8.50 500g Baking Soda for €2.50 I tried it out tonight distilled water (I got from my ACs) and dish soap. It does get bubbly with dish soap. In just two hours the hanger has improved significantly and rubbing against any remaining rust seems to flake it off. I'm going to leave it a little bit longer and see how it goes. I have read that someone even used this solution in an ultrasonic cleaner to clean a seized water pump which brought it back to life.
