How big is your freezer to lose things? All I got is a pack of zooper doopers and a bottle of vodka.
I have a fridge/freezer combo and a full sized stand up freezer.
Why BMW not selling. Having trouble selling it for more than you paid for it like 2 years ago?
Got over the stupid offers and dream boats laying down deposits and not coming back...
Got like 800 bux worth of deposits lol
Speaking of freezer someone is taking the fridge/freezer away from my house. Dat bachelor bar fridge lyfstyle
Getting rid of it or already got rid of?
My brother is looking for a temp fridge/freezer
how the f**k do i tell the difference between tein HA, super street etc?
want to buy some softer springs since the shocks are fine.
4kg rear 6kg front?
well from what i see the best way is to take a blurry picture with your phone then post it to facebook asking what they are.
then argue that they are wrong plus they worth over 5K cos Tien/JDM
  • Like 1
Didnt want to start a whole thread so thought i'd throw it in here. The other day after going down a winding hill when i accelerated to go back up it i got alot of white smoke out the back then it cleared up and happened a couple more times on hills. Then today i took it out and went up and down some steep hills (but these were straight) and all good, went back to the same spot and white smoke again. It's running fine, no hesitation and no leaks on the drip tray or on the concrete at home and oil/water levels are fine. I wouldnt have a clue what is happening, ill just avoid winding downhill roads lol.
Scratch that, probably turbo seals.
seems simple...but checked oil level.
they over filled the missus car on a service (think they filled it twice or some shit), first up hill lost power and blew smoke!
ive been driving it a few times before on the same bit of road and had nothing and i haven't added more oil in it. after the down hill/uphill just light throttle and white smoke pours out then clears up in a few seconds. no smoke any other time when start up or idle or WOT.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
