Hey Greg, just spotted you on the Natsoft Results for Tampered Winton yesterday.
Why you only do 2 laps?
http://racing.natsoft.com.au/results/
-> Circuit
-> Tampered
-> P1 results...
apparently 140+ entrants
and timing crapped it self for the afternoon..
good old tampered, gotta love their hijinks.
I read an analysts report on 88E and seems the large rise was just from the better-than-expected results from some tests on the shale 30,000ft down. Everything from here is going to be slow progress (and expensive). They have 2 major repayments to make by end of march, so that going to hit the wallet but they have access to a lot of (loan) money.
Personally, i cant imagine gaining anything too substantial for the rest of march. If it goes down noticeably, maybe jump on it. But sounds like its a long term thing (12 months or more). Read somewhere that a profitable region is around $53 a barrel, so still a bit to go. And doesnt look like a major is going to make any moves for a while.
Keep in mind that work only happens on that part of Alaska during the summer, so i thought things would shut down October or so. Not sure if they were drilling in Jan/Feb this year though.
-> Circuit
-> Tampered
-> P1 results...
because greg car™
Sounds like you missed the part where seismic photography is due this month along with an independant report assessing volumes of oil down there...if both come back good, there will be a significant rise.
Careful with so called "analysts", many of them stand to benefit from downramping. We've had more than a few for this stock - people telling people to sell and then buying in themselves at a cheaper price lol
On the other hand you have up rampers like me...
How long has it been running ok for? Because whatever the answer its probably not long enough to confidently sign up for a track day
I would have thought dyno tuned and run up many multiple times you would think that if it's gonna be solid it's going to be solid.
I guess I was ultimately wrong about that, but at what point do you seriously assume it's going to be OK?
Fark, milk shake and parma was a bad choice
Worst when you are at client site, and the boardroom is full of directors opposite the toilet & not wanting to destroy their toilets too
Edited by UNR33L
  • Like 1
I never learn to never order milkshakes with heavy/fatty foods. Just asking for trouble.
But so many burger places do exciting milkshake flavours.
Well the 88E website had the analysts findings on their website, so they musnt have thought it was too biased? It certainly didnt sound biased to me, i just took with me what stood out.
I also couldnt help but notice 2x enquiries in March from the ASX questioning the price rises and large amounts of share transactions...
Pretty much all downhill since I decided to buy, just as I anticipated... Should've got it at 4.2 like I was going to but didn't, but I'll probably just keep getting raped for now
At what point did you buy? Leave it in there, to me this is a retrace. When that announcement comes, shit will get real.
Standard procedure, speeding ticket for the stock doing too well. Lots of institutional investors getting on board. But as they say, sell when everyone is buying, buy when everyone is selling.
I just put another 3k into it, so hopefully I'm not wrong.
Pretty much the highest point of the last few days lol
Shit son
Well that high point could easily be the low point of next week; that's stocks for you. There's no reason for it to go down other than people taking profits from the gains they made last week. Once they clear out it'll stabilise or go up, unless we get hit with bad news (doubtful). Leave it in and see what happens I say. I've bought more in so I'm expecting it to climb again.
And here I was thinking you dropped 50k in the 4s...
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
