I call bullshit on this..
went from the old R888 to Achilles 123 Sport (their supposedly track tyres)
grip level dropped so fast it was not funny.
just ended up spinning tyres out of every corner.
I'm currently running the 123s. They're not a proper semi like r888. There more equivalent to a fed 595rsr and I've found they perform similarly. 595 might be a touch better.
do you have any suspension work done to the car? Swaybars, camber, castor adjustments?
Swaybars make a massive improvement in understeering/oversteering.
GTR swaybars, castor arms, camber arms
had 595rs, ku36, RE11 prior and now on RS3 I had significantly less grip with the 123s
180RWKW and just spinning them rest I could stand on the pedal and no issues.
I had RE002's once... Then my wallet got raped and won't be buying Bridgestone sports tyres ever again.
They've probably done like 3000kms in a few years, so will hang onto them until they bald like Louis CK
My experience has been quite different. 248rwkw and grip fine. Maybe the weight of the skyline helps. Dont get me wrong, they're not amazing, far from it. I was just trying to make the point that they're not an r compound.
In saying all of that, would I buy them again? Probably not. Truth be told, the only reason I did buy them is coz they where 150 a corner fitted in 265/35/18. Wallet was happy:) I think i'll be trying the rs3 next.
RS3 are getting up near R888 grip but wear so much better.
I got the 123S as I wanted AD08's but was 2 weeks out from WTAC so think there were my size left in stock!
these were cheap, and I needed tyres for SAUNats.
got a class win at that.
  • Like 1
Dodged 2 court cases for jury duty, one being a 6 week murder trail. Wew.
A short one would have been nice to experience but f**k travelling to city at 9am everyday, that shit is for suckers
Edit: spoke too soon, have to come back tomorrow for another round
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
