Vic Wasteland Thread - 15.0
By Watermouse · Posted
I just bought the Nexus S3 for my gtt, haven’t installed it yet as I’m collecting parts to do everything at once…so far spent $14,000 The Nexus is nearly future proof -
Honda's hybrid system can be easily scaled up to PHEVs. Series hybrid at low speeds, at higher speeds the engine directly drives the wheels but there can still be some power bled off to charge the battery + the electric motor can still provide parallel assistance too. It's really only a question of will at that point. Toyota's PHEVs are selling incredibly well at the moment because of the flexibility. You can run on EV mode when it makes sense, but if you're planning on doing a long highway drive you can still fire up the gas engine and not have to worry about dealing with the rather miserable state of public charging infrastructure. -
Only reason to keep a MAF on your RB25 is to be able to easily calculate true VE if you know what the factory voltage curve represents in grams per second of flow. Also allows you to do things like pull the original OEM ignition + AFR target tables and use those as a starting point for your base map. Once you're well and truly done tuning though there's no need to retain the MAF. -
Do you think they'll merge there performance divisions and we'll end up HoMo?
Very true, if buying new, I would not get an PP either. Minimum is an Elite 2500, which is also considered outdated. Get something that supports DBW, delete that cable throttle. Best thing I've ever done to the Skyline, next best is refreshing the A/C with a new condenser. It's cold, but not as cold as modern car, but colder than most 90s JDM shit boxes imported into Australia.
