i reckon i would go the KPGC10
Nah apparently the c10's drive terribly. Like proper bad. You buy them for looks only. Apparently comparing the c10 to a 240k is like daihatsu charade vs Honda civic.
What sort of ¥ we talking Pat?
Looks pretty sick
$600 for 6 hour tour following a pace-car.
You can also hire the cars & roam about yourself through www.fun2drive.co.jp
Might be tempted to hire another car for 1.5hrs after the NSX.
Your comparison is utterly lost on me
Friend of mine in NZ has a C10. Has an L28 with triple carbs needing a tear-down but i could just go drive his lol
Yeah if doing japan i would prefer to have a bit of freedom. That kei car rally across japan is still my dream experience. Theyre not confident for a 2017 event though :( hope it pulls through
You'd probably want the car to be able to turn a corner without rolling if you're doing 85 turns in a 7.2km touge run...
I'm pretty sure all but a Reliant Robin can achieve this
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
