I actually got lucky charms from Naples in the car now. They are a very superstitious people. I also prayed at a Shinto temple for my car too. Doesn't seem to help much.
Temptation is strong to sell and buy supra/mx5 turbo/something else, but car actually is quite good, just less than the sum of its parts due to something always being almost working.
That said, did go for a ride in a 400awkw well sorted GTR with about 50k spent on it, all done at Racepace and thought "meh, I prefer mine actually" so it's not like it's a complete bucket when running.
great success hifive
I'm still brainstorming my retirement project of convertible with ITB N/A SR20 RWD (or FWD, but think RWD would be more fun). Originally thinking Sunbeam ratrod-ish, then thought old skool Nissan Fairlady and it would be awesome but aint cheap and all are LHD plus tiny engine bay. MX5 would be the easiest option but i just hate looking at them and every man and his dog has one and i dont think i could ever own one.
To be fair my only experience was due to gf wanting to get into cars and "What would you recommend?"
And I said MX5 for all the reasons everyone always 'says' MX5 though I had never driven one.
Then I did, and I'm like ... this is the most fun little car ever.
There's a wild amount of support for parts through pages like http://www.mx5mania.com.au
Just... SO EASY to get parts, bolt on, info is everywhere.
Given a stock one makes like 60rwkw, having 165rwkw with some sticky tyres would be an absolute blast, these things are just toys after all, if you focus on FUN instead of being fully sick and super cool looking man it's hard to beat the little MX5.
But yeah I still feel silly stepping out of one, the stigma is real. (but entirely undeserved)
Thats the other thing that makes my retirement project sounds stupid is the S2000 is basically what i want. Maybe a little smaller and lighter. And easier to work on. And i want to build another SR20.
How tall are you? One of the things stopping me from acquiring that or an S2000 is the height factor.
This is why i don't have one
I have to go custom fixed back and remove the bottom half of the dash.... so... yeh
On the bright side there is no back seat to fall into. Just pull out the seat and put a towel on the chassis.
  • Like 2
Do want a turbo MX5 SE
went in one on the skidpan and was BLOWN AWAY
MX5 SE only has like 100rwkw, with a tune they are 165ish which is about the limit of the block, but.. for the lols, it'd rock! I can't honestly say I'd rather drive a 400rwkw skyline over a 165rwkw MX5 in doing a track day/hill run/going to the shops, etc.
I am 6'2 but my friend is 6'5" and fits into a MX5 with no issues. It's all in the seat and where you set it. There is a SUPRISING amount of room, unless you are literally the mountain, you can fit in a MX5.
I also would prefer a SE with a chip over a S2000 - the MX5 is just simple, easy, and smaller/lighter than the S2000 and going off "the forams" it seems that at the limit the MX5 handles a lot better than the S2000 does. Parts are cheaper, easier to find, so much knowledge, cheap, small, simple, etc etc.
And most importantly.... fun
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
