Vic Wasteland Thread - 15.0
R31Nismoid
 Share
Overheard some tradies talking on the train the other day...
Guy had his appendix out in a rush, operated on that night etc surgeon discharged him out of hospital whenever after, told him take 4 weeks off, and 4 weeks light duties. Guy said no such thing as light duties at his work so surgeon gave him 8 weeks. Health insurance paid it out lump sum.
4 weeks later he goes to his doctor and says he is fit to work, goes back to work and resumes getting paid, doesn't tell insurance or surgeon.
Is that classified as insurance fraud?
If you're working and getting insurance payment, whether upfront or continuous, based on you not working, yes it's fraud. Difficult to chase up with the lump sum though; he'd likely get away with it.
Same deal for income protection when you're unfit to work but continue earning money with a cash in hand or something.
Just did the Toyota Japan factory tour and museum.
Saw Lexus's and Toyota's being assembled on same production line with same people / tools.
I want a Toyota now....
  • Like 1
when toyota sell a LS600L equivalent for less than Lexus money, then ill care. but until then: meh.
whats with this Jimmy guy with a 34GTR? im guessing he is over his head and credit card has bounced all over the state?
 Share
    • You need the kit turbo taipan has shown you because that manifold ia designed have side feed injectors
    • @johnnysr22 did you end up installing the little screen thingy and did it work ?>
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
