12 hours ago, dezz said:
I bought a $3200 mattress about 5 years ago when I moved into my place... 100% latex, no springs etc etc...supposed to be good.
Can't remember how long it took because I've left it so long, but it sagged, and now I pretty much wake up sore every morning.. Comfortable feeling bed, but obviously not doing it's job..
So now I'm finally going through the warranty process... Expecting a call on Monday to arrange a time for them to come and inspect it. They should replace it, but then I'll have to go through the process of choosing another mattress... Most people can sleep on whatever and feel better than I do on a daily basis, unfortunately I'm not that lucky... so it's a big decision..Which obviously needs to be made in a timely fashion
fucking stop lifting you meataxe cunt
You should get a cheap single bed foam mattress and try cutting out a face hole out if it.
Used to love sleeping on my stomach with head to the side as a kid, no pillow. Can't even lie like this for 15 minutes these days; squats and deads turned my neck into tinman.
There are a few proponents of sleeping on the floor - they reckon it's difficult at first but you get used to it. Can't see them having partners without their own dating site though...
Had to sleep on the floor when I f**ked my back a few weeks ago...
The theory behind it is that it's stiff, zero give...so you're body is 100% supported. When you sink into a bed your body can slump into whatever posture the give in the bed allows, muscles then work to try support the body, wake up fatigued as if you've been using muscles in your sleep... Which you have
we sent a bit of coin.
but got one that has different spring rates to both sides as different weights of Katie and I.
I was skeptical, but I used to love traveling for the good hotel beds.
Now I look forward to coming home for the good bed,
Split spring rate, pillow top, from snooze, never looked back.
10 hours ago, 32JET said:
Does anyone have allergies or intolerance's to food?
Took me 22 years to find out i had a food intolerance to fructose..
Lol
Brother found out a fructose intolerance recently...seems to be the new buzz allergy
I should test myself, probably have a slight lactose intolerance, but l'd like to think I'm manly enough to eat anything except a salad
  • Like 1
Hate when this happens. He wasn't even doing anything wrong and they just took his license. Luckily his mum is super cool and will drive him. Lmao what a f**k head. I restrained myself from commenting because i can't be f**ked to talk to an idiot.
Ex was fructose intolerant, so most meals was on fodmap diet. It's doable but pretty annoying, depends on how bad it is. If you can get away with small amounts of wheat and avocado or mushrooms it makes things more interesting
Just paid for bed and mattress from snooze. Decent sale on at the moment, was like 45% discount total. Just annoyed it'll take 6-8 weeks to make, but at least get to choose material
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
