Vic Wasteland Thread - 15.0
R31Nismoid
 Share
That has little to do with a gearbox's power handling ability
Also, case in point...if he doesn't do the 25 conversion he'll be keeping the 20 box anyway
This gearbox will be no worse off bolted to a 25 running much the same power as his 20 - synchros are driving style, oil and clutch setup
Just caught up on 5 pages, missed the exciting mattress talk.
May as well buy a ~1k mattress and replace it every couple of years once it gets shit right?
Dezz mate of mine is selling his bmw x6 rims they look phat (20x10 20x11) but then saw you have new rims already on insta :\
New car came with new rims
X5 rims that Hamish posted would be an option if I was to change the rims over... Not sure which X6 rims you're reffering to, but a few of the sets that came up when I googled X6 rims are pretty shit..
nup, too big.
I assume all the other census' are treated like this, but it certainly feels weird agreeing to it...
Does Liam agree to their name and address and other information on this form being kept by the National Archives of Australia and then made publicly available after 99 years?
  • Answering this question is OPTIONAL.
31 minutes ago, Leroy Peterson said:
nup, too big.
Cunts are assuming you won't live long enough to care about them making your information mainstream
Puts a bitter taste in the latte
the archives and ancestry people already has lots of records from much less than 100 years. im not sure what sort or how much requires a legit reason to access, but im sure if someone tried hard enough...
though i doubt it would contain information like income, residential address (current and previous), employer, number of cars on property, location of work for that week etc. Couldnt they just specify what information will be released to public? surely it really should only be name, DOB, country of origin, completed schooling. Does anyone asides from research/statisticians care about any more than that?
If I was still doing life drawing classes I would have been stumped on what my employer actually produces...
Shitty artwork?
Female hard ons?
The socially acceptable objectification of a male?
Um bruh, Torque kills gearboxes, not Power. So yes, it will be worse off.
Edit: Jonnoo - Definitely cut.
Hmm i hate how they sit pissed sometimes like this?? I don't want to cut it out then have them sitting full retard
Ps this is 32jet, changed user name
57a99e7a02b2a_ImageUploadedBySAUCommunit
Power is directly related to torque, son. These engines aren't different enough that if producing the same power there will be a large difference in peak torque. You'd be talking ~50nm at best. The 25 will bring on the torque and power earlier and that's about it. Hardly cog-stripping material. Unless he's button clutching it with a locker and slicks he'll be right.
 Share
    • Yeah most people that have heard it said it was fine but it's always had me slightly worried. Oil pressure I can't remember off the top of my head but it has plenty, I run 10w60 You're probably right mate, best get ordering some shims! Guessing Nissan is the best place for them?
    • Just wanna preface this and point out I'm a mechanical fitter by trade but have had very little rebuild/machining experience, but I am keen to learn, hence this project. Bit of a write up here so bear with me, just want to make sure I do this right  I've got an rb30e currently pulled down. Planning on putting a 25 head on it and running it in my s14.  Not chasing huge power so I'm just going to try get away with factory bottom end for now.  Started measuring the crank the other day, realised my budget daytona micrometer set wasn't up to the task (surprise, I know). They only measure to 0.01mm but the Nissan specs are to 0.001mm. Anyway, I started measuring anyway and came away with the mains being inline with the oem spec, as well as the big ends, except for no. 5. I consistently got a measurement of a hair over 49.96mm, where all the others were pretty spot on 49.97mm. The lower spec for grade no.1 is 49.961mm. I'm getting access to some better gear my next days off to double check everything, but in the case that the big end is right on that bottom spec, is it pretty much just a case of straight to the machine shop for machining and oversized bearings? I understand I need to measure the tunnel as well to work out my oil clearance, but it's the different grade bearings in the manual that are confusing me. What is generally the process when one journal would still technically be in spec, but in a different grade?  Thanks for coming to my Ted talk
    • You need to visit Ipswich. Plenty of clapped out R32 and R33s running around here as daily drivers. And when I say clapped out, they're how you'd look at a VN, when it's the year 2010...
    • So I checked this out in the weekend.. and look at this. I remember watching the videos. Finally got to see it in person! BRB. Tissues. Got tonnes of other pics and videos too.      IMG_0171.mov IMG_0113.mov
    • For anyone who might be put off by the slightly wacky wheel offset shown on the box photo above, the production models are not like that. Here's some more pics of the actual product (as well as the interior)
