That has little to do with a gearbox's power handling ability
Also, case in point...if he doesn't do the 25 conversion he'll be keeping the 20 box anyway
This gearbox will be no worse off bolted to a 25 running much the same power as his 20 - synchros are driving style, oil and clutch setup
Just caught up on 5 pages, missed the exciting mattress talk.
May as well buy a ~1k mattress and replace it every couple of years once it gets shit right?
Dezz mate of mine is selling his bmw x6 rims they look phat (20x10 20x11) but then saw you have new rims already on insta :\
New car came with new rims
nup, too big.
I assume all the other census' are treated like this, but it certainly feels weird agreeing to it...
Does Liam agree to their name and address and other information on this form being kept by the National Archives of Australia and then made publicly available after 99 years?
  • Answering this question is OPTIONAL.
31 minutes ago, Leroy Peterson said:
nup, too big.
Cunts are assuming you won't live long enough to care about them making your information mainstream
Puts a bitter taste in the latte
the archives and ancestry people already has lots of records from much less than 100 years. im not sure what sort or how much requires a legit reason to access, but im sure if someone tried hard enough...
though i doubt it would contain information like income, residential address (current and previous), employer, number of cars on property, location of work for that week etc. Couldnt they just specify what information will be released to public? surely it really should only be name, DOB, country of origin, completed schooling. Does anyone asides from research/statisticians care about any more than that?
If I was still doing life drawing classes I would have been stumped on what my employer actually produces...
Shitty artwork?
Female hard ons?
The socially acceptable objectification of a male?
Um bruh, Torque kills gearboxes, not Power. So yes, it will be worse off.
Edit: Jonnoo - Definitely cut.
Power is directly related to torque, son. These engines aren't different enough that if producing the same power there will be a large difference in peak torque. You'd be talking ~50nm at best. The 25 will bring on the torque and power earlier and that's about it. Hardly cog-stripping material. Unless he's button clutching it with a locker and slicks he'll be right.
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
