GTS-T in for panelbeating, copped a free loan car cause being not at fault is awesome. Ain't that right Simon?
'16 Hyundai Accent with 2000km on it and new car smell. Shit has come a long way since the 90s. 6.2L/100km vs my 18-19 on E85...they can keep the Skyline.
That... is not right... not with Shannons, since it's not stolen I don't get a hire car. Booo. Do get a coupon code for reduced rates with Hertz, but thats about it
Lol. This from the most painfully rusted on R33 fanboy
Jestful remark is jestful. There's no joy in the Hyundai - don't know what dezz is raving about. Every CVT flare and disregard for speed bumps is soulless.
Why you going through your insurance if not at fault?
  • Like 1
Where is everyone from?
I'm super paranoid about mine getting stolen! I'm from dandenong though haha.
So with my nistune ecu am I supposed to be running a z32 ecu?
Ive got a standard rb20/25 afm on
f**k, do I need to spoon feed you through your whole build?
*1 R33 RB25DET Skyline
The original R33 RB25DET ECU cannot be used with a Nistune board
(a) We recommend sourcing an R32 Skyline ECU which is compatible. These ECUs require little modification and reuse existing O2 sensor, knock sensor and TPS sensor (TPS idle switch is replaced by soft switch in firmware) and come with RB25 base maps and are the recommended ECU for tuning
Nissan ECU Part numbers on front of R32 ECU case:
23710-04Uxx: Uses spare LED output to run VCT
23710-11Uxx: Uses fuel pump idle control output to run VCT
VCT modification information here
Note: Series 2 there is no IACV (Air cond output idle up control valve) output on these ECUs. Recommend wiring IACV solenoid directly to the AC relay (same as Series 1)
Note: Manual transmission models only supported. If using an automoatic transmission model R33 Skyline then reportedly the R32 Skyline automatic transmission control module will work
(b) Alternative option is the Z32 300ZX VG30DE (1990-1992) / Z32 300ZX VG30DETT (1990-1993) ECU
These ECUs use different knock sensors which will need to be disabled, some other modification including connecting both O2 sensors together and removing fuel temp input to the ECU are required. There are mixed reports with tuning these particular ECUs so we recommend using the R32 ECU where possible.
Modification information here
Part number listing information here
https://www.nistune.com/equipment-products-type2.php
So I actually picked up 40rwkw by putting a pod filter on.
I also picked up 750rpm of peak power response by having VCT actually work.
I guess it pays to test shit. Also pretty sure gonna die soon due to above two things.
  • Like 3
That's a load of shit from them...I didn't even involve my insurance company. Just a third party assessor / litigation lawyer who the panel beater referred me to. The woman who hit me admitted fault and her insurance company took on the liability, so everything I'm out of pocket after that is on her insurance, hence free loan car because I ticked the box that said I don't have access to other transport.
Involving the lawyers has turned $1000 worth of panelbeating into a several thousand dollar claim.
  • Like 1
Because I didn't trust the other guy at all, kept trying to avoid insurance... and I had to push to get the name of his insurance company... which turned out to be a broker. I don't have the time or knowledge to do it all myself.
So letting Shannons deal with it, then charge everything to the broker of the other guy.
On Saturday morning a 4wd behind me at a set of lights smashed his foot on the accelerator as soon as the lights went green, without realising that the first car (and thus me as the second car) hadn't started moving forwards yet.
Didn't seem like a hard hit, but once I got home and opened the boot, everything was way off from where it should be. Grrrrr.
Bathurst ticket went down a treat.
that said I drive a clapped out falcon ute, drink VB, and are moving to the country.
much prefer to be classified as a bogan than a hipster..
on a side note, my old Noise Cancelling headphones are officially dead, ordered some Bose QC35's should be a nice upgrade
  • Like 1
That's fair enough as that's also what your insurance company is for, and as the other party has been identified you're not liable for an excess etc. However they're still screwing you on the loan car and probably doing it because they know they might not recover costs from this guy and it'll only add to their bill.
It doesn't take much to cave in the Skyline rear end. My rear end damage that I've had for 2 years (crunched in bootlid and rear bar) came from my car slowly rolling backwards into a car with a bullbar...8km/h max. I'm getting this stuff fixed at the same time as the current front end damage, so should be looking nice again.
    • Yeah, all the crude is used for fuels and petrochem feedstocks (pesticides, many other chemicals, etc etc). But increasingly over the last few decades, much of the petrochem synthessis has started with methane because NG has been cheaper than oil, cleaner and easier and more consistent to work with, etc etc etc. So it's really had to say what the fraction either way is. Suffice to say - the direct fuels fraction is not insigificant. Heavy transport uses excruciatingly large amounts. Diesel is wasted in jet heaters in North American garages and workshops, thrown down drill holes in quarries, pissed all over the wall to provide electricity to certain outback communities, etc etc. Obviously road transport, and our pet project, recreational consumption camouflaged as road transport, is a smaller fraction of the total liquid HC consumption again. If you're talking aboust Aussie cars' contribution to the absolute total CO2 production of the country, then of course our share of the cubic mile of coal that is used for power generation, metallurgy, etc adds up to a big chunk. Then there is the consumption of timber. Did you know that the production of silicon metal, for example, is done in Australia by using hardwood? And f**king lots and lots and lots of hardwood at that. Until recently, it was f**king jarrah! There are many such sneaky contributors to CO2 production in industry and farming. NG is used in massive quantities in Australia, for power gen, for running huge water pumps (like, 1-2MW sized caterpillar V16 engines running flat out pumping water) for places like mine sites and minerals/metals refineries. And there are just a huge number of those sort of things going on quietly in the background. So NG use is a big fraction of total CO2 production here. I mean, shit, I personally design burners that are used in furnaces here in Oz that use multiple MW of gas all day every day. The largest such that I've done (not here in Oz) was rated to 150MW. One. Single. Gas burner. In a cement clinker kiln. There are thousands of such things out there in the world. There are double digits of them just here in Oz. (OK< just barely double digits now that a lot of them have shut - and they are all <100MW). But it's all the same to me. People in the car world (like this forum's users) would like to think that you only have to create an industrial capability to replace the fuel that they will be using in 10 years time, and imagine that everyone else will be driving EVs. And while the latter part of that is largely true, the liquid HC fuel industry as a whole is so much more massive than the bit used for cars, that there will be no commercial pressure to produce "renewable" "synthetic" fuels just for cars, when 100x that much would still be being burnt straight from the well. You have to replace it all, or you're not doing what is required. And then you get back to my massive numbers. People don't handle massive numbers at all well. Once you get past about 7 or 8 zeros, it becomes meaningless for most people.
    • @GTSBoy out of the cubic mile of crude oil we burn each year, I wonder how much of that is actually used for providing petrol and diesel.   From memory the figure for cars in Australia, is that they only add up to about 2 to 3% of our CO2 production. Which means something else here is burning a shit tonne of stuff to make CO2, and we're not really straight up burning oil everywhere, so our CO2 production is coming from elsewhere too.   Also we should totally just run thermal energy from deep in the ground. That way we can start to cool the inside of the planet and reverse global warming (PS, this last paragraph is a total piss take)
    • As somebody who works in the energy sector and lives in a subzero climate, i'm convinced EV's will never be the bulk of our transport.  EV battery and vehicle companies over here have been going bankrupt on a weekly basis the last year.
    • With all the rust on those R32s, how can it even support all the extra weight requirements. Probably end up handling as well as a 1990s Ford Falcon Taxi.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
