Better at having a hand controller? I don't think so
I have a blitz rvit which is a consult port lcd display. Shows all the oem sensors & works with nistune.
Nistune now has flex fuel option so allows even more options
4 hours ago, Mohsen said:
lets talk ECUs
i was going to big single the sedan and go haltech and all that shit but since ive canned it, im thinking about going for a -5 set up now, and obviously PFC again.
i know chris is going to say PFC, so is matt.
yalla. discuss
Do you need an ECU if its never running or driven?
1 hour ago, Leroy Peterson said:
wait, is -5's for the GTR or the sedan? whats happening with the sedan?
but seriously, just dont touch the GTR. leave it, let it appreciate. the less you drive it, the less repairing it will need.
now get some wheels for the stagea
http://page17.auctions.yahoo.co.jp/jp/auction/v467805801
for the GTR, just gonna repair it and have a nice 330ish kw cruiser.
the sedan is being stripped and put into storage.
may come back soon, may come back in like 10 years, i dont know. nothing on the cards for it atm.
motor, front end parts and the nice interior pieces will go into the R.
1 hour ago, Kinkstaah said:
But I carry a laptop and can fully tune my car wherever I go, with better functionality than a hand controller :P
well I carry punch cards in my glovebox so I can change settings on my powerfc
  • Like 1
Urgh....
Did laugh at the end where he yells "Watch your foot" to the girl... but there's no way that the tyre would have even toucher her foot. Would have gone straight over the top of it.
Jesse Streeter?
@luke gtr @Birds Now's your chance to have that camaro you've aaaaaaaaallllways wanted
http://www.carsales.com.au/dealer/details/Chevrolet-Camaro-/OAG-AD-13503676/?Cr=0
Very nice, but a little too modded for one that id own.
6 hours ago, Kinkstaah said:
Or you could Nistune, which is better in literally every way.
Lmao its f**king not. Stop spreading rubbish. You wouldn't have to carry around a laptop to "fully tune your car wherever you go"  if you had a PFC instead of Nistune.
9 minutes ago, Borci88 said:
4th Gear is not removable on Skyline boxes.
Just got this from UK forums
"4th gear is the input shaft effectively. Select 4th and the input shaft is locked to the main shaft and drives straight through at 1.00 ratio - most efficient gear in the box, lay shaft is bypassed"
So stock 4th would be pretty strong then?
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
