so that moment....
you order a cocktail on the beach...
it tastes god.
you order a 2nd.
it tastes better.
you order a 3rd for the road...and slip them a 3$ tip for goodluck
and watch them pour 5 shots in.
fk bali.....
  • Like 1
Heading home from night out in city
See a taxi and ask him if he'll take me home for $60 straight up...pretty reasonable fare as only half an hour drive
*Indian accent* mate I think you better call an Uber or something we can't work for that
Fine man, seeya
Wait 10 mins for Uber and it's a $52 fare
Enjoy your rapidly depreciating taxi licence, dick
  • Like 2
Uber guy, also Indian, rocks up in a clean Civic Type R...very personable and smart dude...talk our heads off about cars. Used to have a 34R (no security guard), now has a 35R and huge property in Bentleigh. Rajab knows why he's driving Uber at 4am...? Haven't had a bad one yet.
So are taxis getting pushed out of the transport market by Uber peeps who don't really need the cash that badly, or are their services and standards obsolete and too low? Mix of both?
  • Like 1
Most uber drivers are ex taxi drivers... Taxis suck dick in general, have for a long time, only now they actually have some competition and they're not happy about it.
Uber surcharges are a crock of shit when in effect though... My normal Saturday night uber ride is around $35-40, but paid $104 for the same trip one morning... No traffic or anything like that, just a 2.4x surcharge... Yes I was informed before booking and accepted it, still horse shit though
Uber also don't allow their drivers to talk on the phone while on a fare... Not sure if the app actually stops their phone ringing while they're on a fare, but they never speak on it or message anyone etc... I've almost died in a few taxis while the drivers were on calls the entire fare.
In summary, f**k taxis. They got complacent due to a total monopoly on the industry, let their standards go to shit, if they were ever anywhere but shit, refused fares that they didn't think were worth their time and had woeful customer service all along
Tl:dr f**k taxis
This surcharge garbage came up on Saturday night. I've been reading things about the drivers banding together to trick the system and go off the grid to activate the surge. Not sure of the truth to it, but when I first ordered an uber it quoted me $55, then as it was on its way, for no reason on my part the request was cancelled. I tried to request another and it tells me there's a 2-2.5x surge charge now.  Keeps fluctuating between that and 1.5. I fk that off for 10 minutes and try again, then it finally gives me a $55 estimate again and I got my driver.
In short, f**k taxis.
Only negative experiences I've had with uber apart from the monster surcharge, ordered one from a mates place, got accepted by a driver, few minutes later it tells me I'm on my way... Pretty sure I was still standing around in my mates place so I cancel it and book another... Same driver gets the job and once again, I'm on my way to my destination, apparently. Called the kunt to ask the nigga if we gon have a prolem, says all good bro, I dispute that on the contrary, things were in fact, not all good, breh. Cancelled again and booked another, which went as it should... Then I see two emails charging me a cancellation fee for the other two... $6 a pop... Emailed uber and they credited me..
Another time a mate dropped $50 in the uber and realised as it drove off... Tried all the uber resolution channels but he never got it back... But as it was not my fiddy, it's not my prolem
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
