2 minutes ago, UNR33L said:
what is laid up cover what happens if you crash it on the road?
1k seems steep if it's just garage cover.. why not just get 3rd party fire and theft?
hell my fpv is like 1k for full comp at market value
I think I'm covered for very limited use, but it's mostly for cars that aren't driven. Thought it would be a good idea while it's being built and then I'll switch to full comp once on the road.
Problem with third fire and theft is Just Cars will only do up to $10k value (it's still $400 with a $900+ excess) and you're not covered for someone damaging or vandalizing your car I don't think.
Wish you could just insure yourself as a driver and not your vehicles.
Ah righto - fair enough.
Car question, got quoted $300 by a shop to fit up some new front brakes, (calipers / rotors) they are supplying the brake fluid and reckons he needs the car for 2.5 hours. Sound about right? Was referred by a friend so assuming he'd half look after me.
Yes I know I could put them on myself but don't have the right tools for the job.
Could buy the right tools for $300
/weakexcuse
Just cars is $625 excess for fire and theft
I know cos I paid it a few months ago
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
