You guys happy paying 75% of my premium for 25% of the agreed value and not being allowed to drive anywhere...?
Of your premium maybe... Mine is/was 1100 full comp with limited use and only I can drive it. I'll take the $500 laid-up when it's off the road thanks...
Trying to get the agreed value over $10k for a pulsar is not easy.
With a falcodore Ute, they know they can void the claim when they find bald tyres with steelies on the back and 22" wheels on the front and no suspension in the rear.
16 minutes ago, UNR33L said:
Sundays ride up Mt Baw Baw was f**kin' wet, had to wait 2 hours for Ambo too after a mate broke his anle:
Don't wanna be that guy that says I told you so
But did this happen 2 days after our argument over jet skis vs supermoto, where I said too many of my mates have done their ankles and collarbones you said you hadn't seen it yet?
Jus sayin ;)
Hope he recovers well; what did he high side on? Brake lock up or throttle close?
Jus sayin ;)
To be fair, he rocked up on dirt bike knobbies and was sliding around corners on purpose haha.
If he had his Supermoto tyres on wouldn't of happened - yeah doctors think 8 weeks.
HEADS UP
had a call from 0423-802-827
sounded like a pleasant guy from the AFP association.
anyway, ran me through a few advertisment deals etc.
wouldnt email the packages for the accountant to see, nor would they leave a name or number.
looked into it further and its the same number that claimed they were from the sherrifs office and i had to pay $500 via credit card or ill get arrested lol
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
