Matt Borci or anyone else
Been out of the loop lately. Looking for a new fully synthetic e85 compatible oil to replace my Castrol Edge 10w60
Figure i dont need the 60w now that i have an oil cooler and no longer track it.
Was thinking 10w40? Which Castrol Edge dont do
On 9/20/2016 at 7:22 PM, Birds said:
Did they have an option where we can pay $500 and you get arrested
i wish
On 9/21/2016 at 0:55 AM, Odium said:
Quick VWL fundraiser to cover costs....
yuuuussss
Penrite ten tenths racing 10w40
  • Like 1
Oil cooler doesn't change anything. Castrol Edge 10w60 all day every day.
  • Like 2
3 hours ago, Leroy Peterson said:
lol does this mean the wheels dont clear the brakes?
gonna finally bite the bullet and get simmons?
http://simmonswheels.com.au/wheeldetails.php?wheel=22-inch-simmons-om
yeh they were way off, 8mm spacer still wouldn't fit - I knew it going into it though
3 hours ago, Jonnoo said:
I got thrown off by the lack of price tag
like anyone here could afford em, too much lost on 88e
fair enough. it was more so on the street oil takes ages to warm up even with a thermostat and hardly goes above 75 to 80 on normal driving
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
