46 minutes ago, Leroy Peterson said:
i was thinking about going.... what time y'all heading in?
i might be helping someone with a stereo install tomorrow
PS calder drags rescheduled due to weather
no time set at this stage
2 hours ago, Borci88 said:
Fair enough then.. maybe I have misinterpreted how you wrote your first couple of posts on the issue.
Buy some Superstreets / Street Advance. Better than Shockworks, better than BC and cheaper than both.
Can't comment on Street Advance or BC, but I just switched from Super Streets to the Shockworks and so far they're more impressive than I remember the Teins being when I first put them in. Once aligned and with new tyres I'm expecting good things.
10:30 at mine
7 hours ago, Mohsen said:
who wants a set of AVS model 5s?
I've got 2 sets...
17x9 w/ 255 all round on the evo
17x8 w/ 235 crapped out skid tyres in the garage.
If the answer to your question is "Mohsen", then lets talk.
3 hours ago, Odium said:
I've got 2 sets...
Wot.
theyre 18x9+25 I think
will check offsets when I can be f**ked.
mint for Evo. I just hate looking at them. Terrible wheels
3 minutes ago, joeyjoejoejuniorshabadoo said:
LOL deets pls
Just broken down in the paddocks of Sandown with about four people exorcising the engine bay
Must be one hell of a demon.
51 minutes ago, Birds said:
Are you an avid supporter of them?
i'm fairly sure everyone on here knows I don't follow footy but the doggies are my team as my late grandfather played for them, so it was pretty awesome to see
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
