Scabies leave trails on your skin as they burrow and are itchy nearly 24/7. You end up with them all over your body too. Bed bugs/mites will just bite you (not sure if they lay eggs under skin like scabies?). You'll soon know either way. The hottest of hot baths doesn't kill them, only rubbing yourself with insecticide...over every square mm of your body...yes in there...will completely eliminate.
And yes old mate google the hypochondriac. Put in itchy arm bite and you get some frostbite ridden decaying limb pic. The health websites aren't much good either with their symptomatic descriptions that match up to...I don't know...f**king everything
- Headache
- Dizziness
- Nausea
- Weakness/tiredness
- Loss of appetite
My engine let go again.
Congealed exhaust gas in coolant looks like poo.
It's noticeably different from coolant and oil mixing, which I have also seen within the last 10,000kms.
  • Like 1
I think more like stock motor and never ever open the motor in any case at all.
And some responsive Borg Warner thing on the side of it.
Or who knows, maybe just put an OEM gasket back on what's currently there, unless the block is cracked or there's a portal to the underworld when they remove the head which is entirely likely.
Drove Grant's car the other day; motor felt very healthy. How is it that a guy who can't even hear his engine can keep it in better nick than you Greg :4_joy:
  • Like 2
Don't have to open the motor to put studs in.
26 minutes ago, blah_blah said:
Perhaps listen to a few of the concerns and suggestions that the engine builder had at the time when he built your motor
I have, every time which is why they were so confused when it arrived back on their doorstep yesterday..
Eliminating things that are "custom" is now my primary goal here. I wonder if things like Scotty's turbo housing/gate/manifold setup causes heat/backpressure/something (maybe it does at 400rwkw at 4000rpm....)
Perhaps the traction control system doesn't work as cleanly as advertised..
Perhaps the metal head gasket didn't seal despite the block and head being super straight and super polished by the machine shop that did it (that also built the engine)
Perhaps the 'custom pistons' that were ordered and sized up for the kit way way back when by someone who was grossly incompetent is causing these fun and games too..
But power was turned down to about 320kw. Given I was pretty happy with that, a standard Neo will be finding its way to that engine bay because I'm really not a fan of "perhaps" (even if something becomes immediately clear as the problem, like last time).
I believe this was brought up as a concern when your engine was built :1310_thumbsup_tone1:
I've had my engine for 3.5 years now and still going strong, only issue was a blocked injector due to e85.
Internally your engine and mine probably same same except for the 2.8 stroker
It was, because back then I had a GTX3076R then with a .82 rear, I took the recommendation and went with a much larger rear to open the whole thing up. Also opened up the intake which would have been contributing to that problem (and picked up 45rwkw lol). But it's possible that the damage had been done, but seeing an engine roll over up top, or an exhaust housing go slightly red doesn't usually result in a blown head gasket. I have never actually run the GTX3076R for longer than about an hour before I changed to a free flowing rear.
And since then the head was lifting under boost (wrong head studs supplied way back then, and re-used by current builder because "ARP studs are reusable". This was discovered when I bought a new gasket and studs because I didn't trust the internet when they said you can re-use metal head gaskets and ARP studs.
And what do you know, the old ones were about 25mm bigger.
Then the block cracked literally 2 days after that was assembled, full rebuild since then, with all the recommendations made, followed.
I directly followed recommendations of people around me... because when you have problems you start looking at people who do not have problems to see where the differences lie...
As to what failed this time, no one is sure yet, other than it's exhaust gases in the coolant.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
